Results 1 to 3 of 3
Thread: sensor or trans?
    '01 Ironman
    sensor or trans?
    Well I have a problem, first off I have 75,000 (hard) miles on my VX.
    When I step on the gas gradually it seems to drive fine (through all gears) but if I give it more gas it does something wierd. Say I am at a light and I give it a good amount of gas off the line, it revs pretty high, kicks TOD up to 50-50 and is VERY sluggish and gives a shake to it. This is the amount of gas that would move the TOD bars before but not all the way to 50-50.
    Now this same problem exists at 45 mph, if I give it a descent amount of gas it seems like it gets stuck inbetween gears searching for the right one. The revs are bouncing all around from 2,500 to 4,250. This lasts a good 5-10 seconds until it finally decides on a gear.
    This all started happening after fording some deep water, so I am guessing I drowned out a senser of some sort. There is definately something wrong.
    Any ideas? Which sensor could it be if you think it is a sensor?
    (praying my trans isn't going out)
    Possibly got some moisture in one of the connectors.
    With the rev problem, I'm thinking trans mode switch or a combo with one of the tod output switches. I guess you could try flushing the undercarriage with clean water and let it dry out. Or flush those sensors and connectors with wd-40, which will clean and also displace water.
  1. Which O2 sensor is Bank1 sensor 1
    By Ebenezr in forum VX Troubleshooting...
    Last Post: 08/05/2014, 06:55 AM
  2. trans slipping
    By Vehi-Cross-Az in forum VX Troubleshooting...
    Last Post: 11/25/2011, 09:32 AM
  3. O2 Sensor/Coolant Temperature Sensor
    Last Post: 04/21/2007, 01:50 AM
