Results 1 to 7 of 7
Thread: leaded fuel
    1999. silver 3254
    leaded fuel
    Anyone knows how I can make my VX take leaded. I am sending my baby to a country where they only use leaded fuel, and I am scared but thats the only way I can get my boss wife to let me buy my second dream car. I know some imported used cars from Japan into this country use leaded so I presume Japan uses unleaded but they modify these carsa to use leaded
    Anyhelp would be greatly appreciated
    James
    2001 Proton VX 0790
    Leaded fuel will poison the oxygen sensor and cats. The cat can be bypassed by making a Y pipe to replace it. From my experience using it in my Eclipse this takes about 10 tankfuls to completely ruin it. Leaded will also run rich, and will trigger a check engine light in OBD2 vehicles because the downstream O2 sensor won't see the value it wants.
    John C.
    Feb 2003
    Talking leaded fuel
    Leaded fuel won't hurt your ride, but it will kill your equipment with catylist which should make your fuel mileage better!!!!
    1999. silver 3254
    So If I understand right, by removing the Cat Conv and the O2 sensor I should be ok ?
    Feb 2003
    Thumbs up removal of catylictic cnvrtr
    you will be just fine by removing the catylitic cnvrtr, if that is your choice.
    2001 Proton VX 0790
    When the O2 sensor starts to fail it wil cycle slower, then eventually read low voltage. The ECU will think the engine is leaning out and dump more fuel in, running full rich. Black smoke, and dramatic reduction in mileage.
    The only real way to run leaded long term is a carb. Leaded should really only be used in an emergency.
    John C.
    2000,black,029
    That's correct. You would get to the point of setting a light. When I worked at Ford we had vehicles sold in S America that ran leaded fuel. They used a special cal that had the codes turned off and used a default value for the o2 sensors.
    Andy from Isuzu America
  1. Help: How to Replace fuel lines going to the fuel rails.
    Last Post: 08/10/2012, 12:10 PM
  2. VX Fuel
    By garfull in forum VX Talk...
    Last Post: 12/23/2006, 11:07 AM
  3. which fuel?????
    By jacobus in forum VX Talk...
    Last Post: 09/20/2005, 11:53 AM
  4. Fuel lid
    By jstein in forum VX Talk...
    Last Post: 11/25/2004, 08:47 AM
    Last Post: 08/31/2004, 12:47 PM
