Results 1 to 4 of 4
Thread: Problem with HID headlights
    Mar 2004
    2001, Kaiser
    I have had the Brightstar HID headlights for over a year now; and love em.
    However recently one of the lamps immediately turns off after turning on. The other side is fine. Any ideas what might cause this? Obviously the bulb isn't burned out, because then it wouldn't come on at all. All suggestions, ideas appreciated.
    May 2002
    2000, Proton Yellow, VX, 0584
    Checked the fuses?? Of course, you did... May be the ballast going out or may be grounding out.. Check all of your connections for being loose and or wet/damp or chafed.
    Scott / moncha.com
    Wink
    Switch bulbs side to side, switch igniters side to side, switch ballast side to side...whichever one causes the problem to switch sides is the culprit.
    Mar 2004
    2001, Kaiser
    Thanks for suggestions.
    Thank you for your suggestions.
    I'll give them a try.
  1. LED headlights went out
    By simonsayz1 in forum VX Talk...
    Last Post: 09/21/2016, 10:38 PM
  2. LED headlights
    Last Post: 08/25/2014, 08:01 PM
  3. Driving problem fixed/TOD problem realized
    Last Post: 02/26/2010, 06:57 AM
  4. when do you use your headlights?
    By etlsport in forum Polls
    Last Post: 08/19/2009, 12:35 PM
  5. Headlights?
    By Thmstec in forum VX Talk...
    Last Post: 03/10/2008, 07:46 AM
