Results 1 to 14 of 14
Thread: alternator install questions
    Oct 2004
    2001, ebony, VX, 0982
    I was gonna replace my alternator myself, i have some auto know how but not alot. on the do-it-yourself meter from 1-10, im a 5. About how long will this take me, will i have to remove the whole enigine to get to the alternator, and will the job need any special tools? Should i purchase a chilton or haynes repair manual along with the alternator?
    Feb 2003
    dude, really easy. The only problem you might have is getting the bolts to go all the way though from lack of visual. But, a mirror solved that problem really quick. Very easy. Don't be scared.
    2001 Proton VX 0790
    Alt comes out from the bottom. Obviously disconnect the battery first. It may be necessary tofile the new alt at the pivot bolt hole to get it to fit.
    John C.
    Oct 2004
    ok thanx guy it is gonna be shipped within the new few days so maybe i'll barrow my brothers digital camera and take pic's to do the how to's. again, thanx for the confidence boost
    You may be able to look up the alternator (GM) upgrade on planetizuzu.
    There are some great pictures of someone else's install on the larger alternator.
    Oct 2004
    the new alternator should be arriving wedsday or thrusday i should be checking in for a helping hand.
    Oct 2004
    Need Pulley Diagram
    i need a picture or a description of how to loosen the pulley so i can replace my alternator.the belt is too tight. how to get it off? allen wrench? how do i adjust the tension of belt?
    May 2002
    2000, Proton Yellow, VX, 0584
    There is only one belt and it is adjusted by the tensioner. Here's a thread that I searched on serpentine belt
    Scott / moncha.com
    Oct 2004
    do i need a allen wrench for this job? or should i be loosening the bolt about 3inches to the right of the allen wrench bolt?
    2001 Proton VX 0790
    you aren't loosening the bolt. You are putting a wrench on the bolt to act as an extension of the pivot arm to gain leverage.
    When you pull it and feel the spring, you'll understand.
    John C.
    May 2002
    It's not an allen type bolt. The tensioner is a 14mm hex head bolt..
    Oct 2004
    well thanx for all the help guys. but im gonna go and kill my isuzu dealer tomarrow, about 4 hours it took me to put it in and when I slapped it on the battery light still is on and the TOD still doesn't work(which might be a good thing with WDC coming up now i can peel out) but they told me that an alternator would fix it all and it fixed nothing. so im gonna go raise hell and make a scene until they fix the problem! grrr am i pissed!
    You might want to charge your battery with a charger before you go on the warpath. It's possible that your last alternator wasn't charging and left the battery in a low charge state and the new alt hasn't brought the level up yet.
    You could also try running the engine for 30-45 minutes with ZERO accessories turned on to see if it brings the charge up.
    Do you have a voltmeter to check the battery voltage in a running and non-running state?
  1. 130 amp alternator
    By Nikad92397 in forum VX Modifications...
    Last Post: 12/04/2016, 11:08 AM
  2. Alternator
    By reddragon in forum VX Troubleshooting...
    Last Post: 06/10/2013, 07:42 PM
  3. Trooper Skid Plate Install -- Pictures and Questions
    By Grant Eaton in forum VX Talk...
    Last Post: 08/25/2009, 01:21 PM
  4. Alternator went out
    By jgrish in forum VX Troubleshooting...
    Last Post: 09/27/2005, 04:03 PM
  5. Head unit install questions
    By DeafVX in forum VX Talk...
    Last Post: 08/30/2003, 05:44 PM
