Hi guys
If I brake at 30-60 mph the steering vibrates, could this be a suspension or brake problem ?
Thanks
james
 Super VXer
						Super VXer
						Hi guys
Thanks
james
		Most likely a warped brake rotor...had the same thing happen on my yUgo.
what condition are your tires in?
2000 Black VX 105k
Almost certainly one or more of your brake rotors are warped. You should certainly check your tires for even wear, but if they were the culprit, you'd feel the vibes while driving, not just while braking.
Good luck!
