Results 1 to 15 of 20
Thread: Help! how many had/have hood insert problem?
    Mar 2003
    1999, Ironman VX, 2024
    I haven't had any cracks in my hood insert but I noticed the other day that the inside drivers side corner is lifting up. I'm worried that moisture and winter freezing/thawing is going to get underneath and erode the hood. Does anyone have a suggestion as to how I can get that corner glued back down properly. I really want to do it myself if I can but I'm not sure what type of adhesive to use.
    2001,Ebony,VehiCROSS,1092
    The hood insert is bolted down, so maybe the nut just worked loose. Worst case, the adhesive holding the bolt to the back of the insert has failed, and you'll need to reglue it (JB Weld should work). Pull out the round plastic retainers that hold your underhood sound mat in place & remove it to get at the nuts that hold the hood insert. Note - the washer nozzles also have to be removed to take out the insert.
    '01 Firefox
    Let us know how the JB Weld works...Mine is doing the exact same thing!!
  1. Need Hood Insert!
    By HOT_WASABI_JUNKIE in forum Archives
    Last Post: 06/24/2016, 02:19 PM
  2. Looking for Hood Insert
    By jtirado in forum VX Talk...
    Last Post: 01/18/2016, 07:00 PM
  3. OEM Hood Insert
    By VXNIT in forum VX Talk...
    Last Post: 01/14/2007, 02:14 PM
  4. VX hood insert???
    By bigdogdeee in forum VX Troubleshooting...
    Last Post: 04/13/2005, 06:57 PM
  5. Red Hood Insert?
    By totallto in forum VX Modifications...
    Last Post: 02/10/2004, 09:45 AM
