Results 1 to 8 of 8
Thread: Engine Ping
    fuel quality is getting worse
    very true, instead of getting raped for higher octane fuel do octane boosters (additives) work?
    Nov 2008
    1999, Astral Silver Metalic, VehiCross 0385
    water?
    Could Be water in fuel tank.... going up a hill mighta put the water pocket right at the fuelpump area degrading octane rating.... reason for being unable to reproduce is cuz you used all the water in your tank already.....
    Gas floats on water water in gasoline tends to "stick together" in bubble kinda like italian salad dressing.
    but then again.. i'm not an auto mechanic.. just a helicoptor mechanic....
    -Chris
    2000, Kaiser, #0016
    Sounds like a candidate for some Seafoam treatment.
    Quote Originally Posted by Grif View Post
    Already done, and if it was water in the tank, I should have been flushed out after a couple of tanks worth of gas, I may try and pput 93 octane in it the next fill up and see if that helps.
  2. ping-pong with nunchucks
    Last Post: 09/06/2009, 03:30 AM
  3. Matrix ping pong
    Last Post: 10/07/2006, 09:02 PM
  4. Knock knock.... ping....
    Last Post: 05/09/2006, 06:47 PM
  5. Replies: 1
