The W7 and amp are large components and that ub is a monster. I would build a correct mdf and fiberglass box for the cargo area if i were you. Make sure you give that sub the proper air space and it will scream.
Drive it like ya stole it!!!
2002 Axiom XS
-20" Eco 820s with Goodyears
I managed to squeeze my large Orion HCCA 250 Amp and two twelves in the rear door. IIRC, each sub required a minimum of 1 cubic foot sealed air, and I squeezed just a little over that. I used some stuffing material inside to help increase the perceived volume, and my subs sound really nice. However, if I had to do it over again, I might consider mounting the amp elsewhere to get some more volume for each of the subs, or even using just one sub. I believe those subs can be mounted is as much as 3 cubic feet of air for competition grade systems.
I don't know what the volume requirement is for your JL 12, but you should easily be able to get about 2 cubic feet, which is enough to make most subs sound incredible.
according to the owner's manual, the recommended volume for the sealed enclosure is 1.375 cu ft; and for the ported enclosure is 1.75 cu ft.
i am still thinkin how to build the box, kpaske, can you tell me how you build yours? it's kinda hard to build a sealed box and mount it to the round door. (i couldnt get through your web site i don't know why.)
blue HID head light, custom license plate "GOVEHIX", Pro M mass air flow, black safari light bar from Tone, PIAA 194 fog light intalled, PIAA 550 fog light lamp installed, custom bull bar extention installed, Levoc ultra metal pedal set, Bioharzard sticker at the rear glass, Recaro red cellphone holder and razo steer cover.
Occupation: Full Time VX Driver
Yeah, sometimes my router locks up, blocking access to my web page. It's back up if you want to try again.
Anyhow, since I was building a box with two seperate, sealed chambers, I used a solid piece of MDF running straight down the middle, from top to bottom as my starting point. I cut one edge so it lined up nicely inside the door, effectively splitting it in half. Then I built an MDF "frame" that went around the circumference of the outer edges of the door, and a flat board that the amp would later mount on. Once this rough frame was built, I stapled felt around the edges, creating a surface to lay my fiberglass on. It's probably hard to imagine what I'm talking about without seeing it... unfortunately I didn't take any pictures, but if you really are interested in duplicating the design, I'll try to explain it a little bit better and in more detail.
I also considered not using fiberglass at all -- the door would probably accept an "octogon" shaped sealed MDF box with a slanted front, and with this design you should probably not have much trouble squeezing 1.375 cu ft out of it.
kpaske, just come up with a question, did you put extra battery and capacitor to support your sub system?Originally Posted by kpaske
Nope, I'm using an Optima Blue Top battery and 0 guage wiring. I ran 0 gauge from the negative battery terminal to the block, then to the chassis ground, as well as 0 guage from the positive battery terminal to a distribution block behind the driver's seat. My alternator is stock. It seems to have plenty of juice for my two big amps, though I still plan to run a 0 guage from my alternator to my positive battery terminal sometime in the future. My lights dim a little bit sometimes when the system is REALLY thumping, but I've never had a problem starting or having my battery run out.
From what I understand, lowering the resistance by using really large wires helps quite a bit (often solving a lot of power issues). The key three points are the wires from the negative to block to ground and from positive to alternator.
Here's a link to my cardomain site that has picture of my JL 12" sub. I had it custom installed, and absolutly love it. This thing hits and I love the way it looks in the back door! Take a look and let me know if you have any questions.
Adam
Here's the link:
http://www.cardomain.com/ride/2074072
