Results 1 to 15 of 15
Thread: Fuel Leak
    '99 Ebony Black VX, 0339
    Install looks fine and it is tight back there. No hose for that is included in any kit as it is not necessary - if they used the coolant or other hoses in the kit, they should not have as you need higher pressure hose (those marked gas are for low pressure systems and are insufficient for use on an injected system) And had they attached the stock fitting back to the block where it came from, there would be less stress on the connection. What markings make you think it came in the kit as I have also never seen red hose in any of the kits?
    The hose markings are in english and describe dual use hose (Gas and PVC). The local auto parts store hose looks like this.
    Roy
  1. Oil pan leak
    Last Post: 09/11/2014, 04:34 PM
  2. Need help with oil leak
    Last Post: 06/10/2013, 05:42 AM
  3. Help: How to Replace fuel lines going to the fuel rails.
  4. Fuel Injectors and Fuel Pump
  5. Fuel Smell/Leak
    By Hotsauce in forum VX Troubleshooting...
    Last Post: 06/24/2002, 08:28 AM
