Results 1 to 15 of 15
Thread: Fuel Leak
    I was thinking of the entire armored replacement section be flexible.
    Roy
    May 2004
    Used to own #777
    I had to replace mine when it broke below the regulator. I had had the supercharger off once, and replaced the IMGs once, and the original supercharger makes 3 times that that hose was flexed a lot. It just fatigued enough to develop a leak. Anyway I ended up bypassing it as I could not get a tool in there to remove what was left of the hose. My new hose runs around the top instead of between the engine and the firewall.
    -Tad
    Tad,
    Where under the car, did you cut and attach the new hose?
    Where is the stock line routed at the back of the engine?
    Roy
    May 2004
    Used to own #777
    I didn't cut the old line, I just disconnected it next to the transfer case where it transitions from rubber to steel.
    The two lines come up on the top of the transmission and split. One connects to the fuel rail on each side of the engine.
    -Tad
    Got the car back today.
    Photos show the gas hose was just cooked by the EGR valve and cracked open. Four circumferential cracks show as the hose is bent.
    The gas hose markings indicate that this hose was added by Alpine during the S/C install. This is after about 18 months of driving.
    Next, I will replace the hose again, but with teflon lined, silicone, and metal braided hose. At least I now know exactly what is required to fix.
    I do not know why I would have an especially hot condition as compaired to other S/C installation.
    Tone, do you see anything unusual?
    Roy
    bump
    2001 Proton VX 0790
    Replace the bent banjo tube with a longer straight one, point it to the passenger side fender, and use a new longer rubber hose routed behind the passenger side valve cover.
    John C.
  1. Oil pan leak
    Last Post: 09/11/2014, 04:34 PM
  2. Need help with oil leak
    Last Post: 06/10/2013, 05:42 AM
  3. Help: How to Replace fuel lines going to the fuel rails.
  4. Fuel Injectors and Fuel Pump
  5. Fuel Smell/Leak
    By Hotsauce in forum VX Troubleshooting...
    Last Post: 06/24/2002, 08:28 AM
