Results 1 to 6 of 6
Thread: Electric Radiator Fan
    2000-Ironman 0219
    It appears that my front Electric Radiator Fan does not come on. VX ran up to 215 degrees in water temp (scan gauge reading) and I pulled over and idled high to reduce heat along with turning off the AC. It was 105 outside with hilly driving. I have already removed the Electric Radiator Fan, to hook up directly to 12volts. I wonder if this fan only comes on with the AC, I have never noticed it running since I have owned the car.
    Any advice, experience?
    Oct 2004
    99 Victory White Ironman 0685
    electric fan
    I have had my VX for over a year. I drive in hot Dallas traffic, went to Moab, offroad in east Texas with temps near 100 ,with no problems and my fan is not connected. I think it was wrecked and bodyshop never reconnected it. I keep meaning to fix it, just never get to it.
    Chi Dog...Dog is my Co-pilot
    Onward thru the fog
    May 2002
    2000, Proton Yellow, VX, 0584
    You were correct in say the Electric Fan only comes on when the A/C is on it's to increase air flow over the condenser core. I've never seen it come without.
    Scott / moncha.com
    2000-Ironman 0219
    Thank you for your replies.
    I never hit the red line but my scan gauge tells me the differences in temperature. At 215 I pull over, it should run cooler than that I think.
    Feb 2004
    '01 Ebony #0830
    Oil Cooler?
    Mine comes close to overheating daily in the Vegas 115 Degree heat. I was wondering if anyone has installed an oil filter "sandwich adapter" and ran oil lines to an external oil cooler?
    SilverBullet75
    Formerly: '01 Ebony VXSTLTH
    Now: '08 Saab 9-7x Aero 6.0L
    1999,White,Iron Man,1429
    The electric fan is the a/c condenser fan and is controlled by the high-pressure switch on the a/c drier, so it was not designed to aid in engine cooling. The engine fan has a viscous drive that may be your problem. If there is an accumulation of dirt due to the loss of viscous fluid at the hub, then I would replace it.
    After I installed the winch I seemed to notice an air flow problem at a stop. The a/c would not cool as well but the condenser fan was on. I installed an after market electric fan on the left side of the radiator that took care of the a/c problem as well as running a bit hot on the trail. I have never had a problem on the road no matter what temperature.
    Todd
  1. Electric cars a bad idea?
    Last Post: 01/02/2011, 09:22 PM
  2. The Electric VX
    Last Post: 07/25/2007, 11:03 PM
  3. Who Killed the Electric Car?
    By JAFO in forum VX Talk...
    Last Post: 01/07/2007, 01:42 PM
  4. Electric fan in front of radiator
    By - s a i n t - in forum VX Troubleshooting...
    Last Post: 06/02/2006, 10:22 PM
  5. Electric Exhaust Cut Out
    By MachineVX in forum VX Modifications...
    Last Post: 12/09/2004, 01:46 PM
