Results 1 to 6 of 6
Thread: Where is door relay located???
    NC 1999, ironman, 0358
    Finally doing popper mod. Previous posts have tons of info but I am unable to find the door relay. It is supposed to be behind the drivers side kick plate. How do I reconize it? Have tried shop manual drawings...even disconnected (1 at a time) the 3 relays behind the kick plate, to no avail. Even looked for relays with light green white black stripe (as per previous post).
    Western North Carolina...
    Veni, Vidi, Velcro
    May 2002
    2000, Proton Yellow, VX, 0584
    Are you referring to this post?
    I think the relay is actually under the driver's side door panel. That's where I hear the click when locking and unlocking the door.
    Scott / moncha.com
    2001,Ebony,VehiCROSS,1092
    Which door relay are you referring to? If you are talking about the relay for the remote mentioned in Moncha's post above - it is behind the driver's kick panel. It is wrapped in a foam material and pushed into a hole in the inner fender. If you pull off that black panel and get a flashlight down there, you will find it in a hole there. The wire colors will tell you if you have the correct relay.
    Here's the entire thread that may help you if you are trying to hook up your popper to your remote:
    http://www.vehicross.info/forums/sho...=popper+remote
    That is the post I'm working from...tomorrow I will look for the foam-wrapped relay...that was exactly the type of info I was looking for. Many thanks. Don
    OK found foam covered relay and connected as per drawing...works as promised...life is good...thanks. Don
  1. turn signal relay ??
    By orion in forum VX Troubleshooting...
    Last Post: 07/13/2014, 10:23 AM
  2. relay switch for windows
    By Dumke in forum VX Troubleshooting...
    Last Post: 04/30/2007, 02:35 PM
  3. Where is the EGR located?
    By ScottinMA in forum VX Troubleshooting...
    Last Post: 06/26/2005, 07:18 PM
  4. Where is this part located??
    By Yefim in forum VX Troubleshooting...
    Last Post: 04/21/2004, 09:39 AM
  5. Relay keeps clicking and will not stop.
    By loco6464 in forum VX Troubleshooting...
    Last Post: 09/25/2003, 07:22 AM
