Results 1 to 4 of 4
Thread: OBD code help pleeese!
    2001, Yellow, Vehicross, 0786
    check eng light came on this morning, 4 codes
    P0137 circuit low volts Bank 1 Sensor 2
    P0157 circuit low volts Bank 2 Sensor 2
    P1171 manufacturer specific (came up twice)
    Any brainiacs out there know whats going on?
    Pete
    '99 Ebony Black VX, 0339
    First 2 refer to the O2 sensors and are probably caused by the last one "Fuel system lean during acceleration." Cheak for airleaks around MAF and more likely intake gaskets. Good luck and try not to drive it too hard until you resolve the issue.
    '99
    Pete, gently clean the MAF sensor wires with a q-tip and alcohol or spray them with electrical contact cleaner. Dirty MAF sensor wires will cause those three codes with the P0101 MAF sensor problem code showing up a while later.
    Mark
    awesome, thanx guys! had a crappy day at work yesterday so i was kinda hammering it a bit!
  1. Abs Code 35
    By johnny010 in forum VX Troubleshooting...
    Last Post: 01/08/2009, 10:11 AM
  2. TOD throwing code 13
    By Nick in forum VX Troubleshooting...
    Last Post: 02/10/2007, 01:54 PM
  3. fault code
    Last Post: 09/27/2006, 01:18 PM
  4. PO 440 - Code
    Last Post: 01/03/2006, 08:21 PM
  5. Cel Code 405?????
    By Mr. I-MAN in forum VX Modifications...
    Last Post: 09/10/2004, 08:13 AM
