check eng light came on this morning, 4 codes
P0137 circuit low volts Bank 1 Sensor 2
P0157 circuit low volts Bank 2 Sensor 2
P1171 manufacturer specific (came up twice)
Any brainiacs out there know whats going on?
Pete
Pete
First 2 refer to the O2 sensors and are probably caused by the last one "Fuel system lean during acceleration." Cheak for airleaks around MAF and more likely intake gaskets. Good luck and try not to drive it too hard until you resolve the issue.
 Super VXer
						Super VXer
						Pete, gently clean the MAF sensor wires with a q-tip and alcohol or spray them with electrical contact cleaner. Dirty MAF sensor wires will cause those three codes with the P0101 MAF sensor problem code showing up a while later.
Mark
awesome, thanx guys! had a crappy day at work yesterday so i was kinda hammering it a bit!
