Help.....
The plastic tabs at the bottom of my drivers side window have broken, causing the window to fall into the door. These tabs are glued to the window and attach the window to the window regulator. My local Isuzu dealer says the part ONLY comes as a window assembly,(WITH WINDOW) for $200.00. I can't belive you can't buy the two plastic parts without buying a window too. Anybody know more about this? Is there a part number? For now I have the window propped up in the closed possition.
Any help will be appreciated.
Thank you,
Howard 0761
