Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Thread: Stuck Door Lock!
  1. #16
    '99 Astral #1977
    My passenger door is stuck/locked the same way. I tried a slim jim and I can turn the key while working the slim jim, but the lock won't budge. Can't get the door panel off to have a look. I'll try disconnecting the battery to see if the solenoid will let loose.
    RichD
  2. #17
    Sep 2008
    1999 Silver 1065
    getting unlocked
    when my door gets stuck locked, I use a screwdriver to unscrew and adjust the handle from the interior...then it always unlocks. Seems to only happen when I lock the driver door with the power lock button, from the inside when the door is closed
  3. #18
    Getting unlocked
    Well AnalogVX, did you ever get the door unlocked and if you did, tell us how you did it.
    Knowledge is power!
  4. #19
    Feb 2015
    2001, Silver, Base,
    New power locks?
    So my power lock on the driver side doesn't work. Key is fine, but neither my button or fob opens it. Only the passenger side works. I just got a new alarm put in and they think it's a motor. Any resources on where to get a new one? Also, while I'm on the topic, my window motor is getting sketch...Is there a particular one you guys recommend as a replacement?
  5. #20
    Oct 2011
    1999 black vx
    my passenger did this also,
    i spent around 30 minutes pulling door lock up and lifting outside door handle while jiggling lock and it opened. the door lock actuator was the culprit. i want to thank everyone for this forum as it is the best source for information for these rare vehicles
  1. Ignition shifter lock stuck
    By angeno in forum VX Talk...
    Last Post: 06/03/2013, 04:25 AM
  2. HELP - Door Lock Issue
    By mikieg in forum VX Troubleshooting...
    Last Post: 03/26/2011, 08:19 PM
  3. door lock motor
    By protonvxmatt in forum VX Troubleshooting...
    Last Post: 04/01/2009, 08:16 PM
  4. Door lock internal mechanism
    Last Post: 07/10/2008, 01:24 PM
  5. Door Lock Engaging while Driving
    Last Post: 02/14/2008, 05:22 PM
