Results 1 to 8 of 8
Thread: Trooper CV=VX CV?
    Dec 2002
    '01 Ironman
    Trooper CV=VX CV?
    Well my driver side CV went out and am now looking for a replacement. I found a 2001 Trooper CV for $60, will it work? Is there any other year that would work? Any help appreciated
    Thanks,
    Alan
    Feb 2003
    certain years are same measurement, but am not sure which years.
    measure them is all I can say or call St Charles Isuzu and ask for the part numbers for both vehicles with parts in question and see if they are same.
    If you need help changing out your cv's then pm me and I'll give you my number and you can call me and I'll help you out.
    Jul 2004
    2000 Black VX 0363
    I'm going out on a wing here, but I'm guessing that Yes, the same model year trooper CV will fit the VX.
    In 97 I believe, Isuzu widened the front axle, making the shafts longer. Just stick to the same model year trooper part and you *should* be ok. One way to find out would be to find a part number for them both and see if they are one in the same.
    DISCLAIMER: I haven't actually replaced the CV's on the VX yet so I cannot say for sure.
    2000 Black VX 105k
    Dec 2002
    '01 Ironman
    Well as it turns out, no it will not work. The VX is it's own animal. I guess it is possible that the Trooper has Driver side drop instead of passenger like ours and maybe the passenger CV would work? But most likely not.
    Feb 2003
    for cv's it doesn't matter if passenger or drivers side drop. Unless you are talking axle shafts...but even so you just swap the brackets out and turn sides. as long as they are same measurement, improvise adapt overcome.
    Dec 2002
    '01 Ironman
    Exactly Spazz it was a short shaft when I needed a long shaft.
    Feb 2003
    so, your axle shaft broke..I am talking about the one that is from the green housing and runs inside the the housing to the 3rd member..."SHORT or LONG SHAFT" or did just the cv shafts or castles inside the cv boots break???
    Try a search as I'm pretty sure there is interchangability for one side. The other side is vx only.
  1. 98 Trooper
    Last Post: 03/01/2014, 08:37 PM
  2. Will a Trooper ECU work??
    By Ebenezr in forum VX Talk...
    Last Post: 08/26/2011, 01:02 PM
  3. 93 Trooper RS for wife
    Last Post: 08/23/2011, 07:18 PM
  4. 89 Trooper RS
    By Hide in forum VX Talk...
    Last Post: 11/12/2010, 05:25 AM
  5. TROOPER vs VEHICROSS
    By jacobus in forum VX Talk...
    Last Post: 09/24/2005, 08:07 PM
