Results 1 to 6 of 6
Thread: Engine Overreving
    Thanked: 7
    Post
    There are a number of reasons this can happen. IF you do a search on "idling" you will have many posts on the subject. Perhaps through them you can find similar stories compared to yours.
    Good luck!
    Anita
    2000 Ebony #263
    AnitaProtich.com
    Aug 2004
    01, Kaiser Silver, VX, 1102
    What kinda RPM's are you talking about at initial start and at idle. Also, is AC on or off at start...
    May 2005
    2001,DRAGON GREEN,
    Sometimes hot, sometimes cold, ac on usually. Revs about 3500rpms.
    May 2004
    2001, Ebony Black, VehiCross, 0432
    I have the exact same thing happen on startup as well. I don't have any idling issues though. I took it to the dealer and they said they couldn't repeat the problem. I've tried searching on here as well, and coulnd't find any pertinent information on the startup issue!
    '99 Ebony Black VX, 0339
    Idle Control Valve or TPS sounds like it is sticking - located on the throttle body with 2 torx screws - remove and clean all areas with carb cleaner including butterfly valve. If not this, then probably a vacuum leak / cracked intake gaskets.
  1. Looking for a engine and.
    By Nikad92397 in forum Archives
    Last Post: 07/06/2016, 04:55 PM
  2. Need Engine
    By Crasca in forum VX Talk...
    Last Post: 03/24/2015, 12:48 PM
  3. '99 Vehicross Engine Knock / Engine Replacement Suggestions
  4. Replies: 1
    Last Post: 03/15/2004, 11:02 PM
