Hello VXers! My issue is with the TOD system. I hope someone has some helpful into for me. Some info and some questions below.
The otherday the TOD lights went full on front (and rear). I could feel a bind or dragging when turning the wheels and moving forward or backward.... sharp turns etc. It might have pulled out of it the otherday on the way to work, but if it did, it started again immediately. I would be willing to say that it never stopped. The CHECK light is also blinking.
I pulled the codes using the light diagnostics by shorting pin number 8 on the diagnostic connector. I got codes:
16 and 21
These are the front speed sensor, and the throttle position sensor respectively.
I don't think the issue is with the TPS, although it is a TOD sensor of sorts so it could be. I am leaning to the front axle sensor that is on the transfer case.
When I hit up isuzuparts.com I run into several (4)"speed sensors"...
Number one is listed as a Powertrain part and the others are listed as Anti-Lock brake parts. Two of them look to be exactely the same.. (could be 'A' and 'B'...?) When I talk to the dealer, they sound like they are looking in the right place, but they quote me what seems like it could be a wheel/hub speed, anti-lock brake sensor from the descriptions below.
(1) VEHICLE speed sensor, Vehicross 99-01 $180.88 $0.00 $144.70
Electrical - Powertrain control - Vehicle speed sensor
(2) FRONT speed sensor, Vehicross, Right 99-01 $350.94 $0.00 $280.75
Brakes - Anti-lock brakes - Front speed sensor
(3) FRONT speed sensor, Vehicross, Left 99-01 $350.94 $0.00 $280.75
(4) REAR speed sensor, Vehicross 99-01 $446.25 $0.00 $357.00
Brakes - Anti-lock brakes - Rear speed sensor
When I call dealers, they wittle down the into the parts catalog and quote me an 'A' and a 'B' sensor. I think, based on location, that the one I need is the 'B' senosr (if I indeed need it at all), but it seems that the sensor is labeled as being for "anti-lock" brakes... I am a bit nervous in ordering due to the price differentials, and simply because I can't seem to find a parts guy that knows what is what. (or can really make me confident that he knows what he is sending me)
So I am thinking I will just replace the front axle sensor that is on the transfer case. I am hundreds of miles from a dealer, and don't have a reader to do the proper test to make sure, but the flow chart on the fault code leads pretty clearly to the sensor.. or a connection concerning the front speed sensor... etc.
Does anyone have an idea what the part number for that sensor might be? I just would really hate to get the wrong thing... I get impatient with parts guys, as I am a parts guy myself. Dealer parts guys (some anyway) might as well be selling parts for horse carriages for all they know... sorry.. starting to rant... better end it here!![]()
Thanks for any info that anyone has! Keep on VXin'!
fourteener
