Results 1 to 15 of 16
Thread: Oil Drain Valve
    2001,Black,VX,0701
    Oil Drain Valve
    Just came across this oil drain valve (see link below) while playing on the net and am thinking of getting it but thought I would see if any of my fellow VXers had an opinion on it. About the only bad thing I could see is if some one new you had it and wanted to mess with you they could drain your oil easily. But then again it's not that hard with a wrench. Any thoughts or has anyone put one on?
    http://www.fumotousa.com/
    Aug 2003
    1999,Silver,Vehicross,0928
    tats pretty cool....
    I've had one of those (a similar product). It's best if it is hiding behind a skidplate (as it was on my GC). It sticks out about 1.25", and I was always afraid that a rock was going to take it out. On the other hand, it was nice to not have to worry about stripping threads or getting hot oil splashed down your arm with every old fashoined oil change. I'd definately do one on the VX.
    2001,Black,VX,0701
    Just ordered one from MY-TEC Sales Inc. PH# 404-505-0163 (in Atlanta GA) cost was $19.92 plus shipping. I should have it in a couple of days. I ordered part # F-106N hope it fits will post when I get it installed.
    Nov 2002
    I've got the Fumoto installed on both VX's and the Trooper. Excellent product and you'd have other problems if something broke it.
    Feb 2003
    I think the Fram oil drain thingy is the best.
    1999, Ebony Black, VX ,1976
    i would be afraid of hitting on something when wheelin and breaking it. i have some dents in the oil pan already so i know it would be possible. shawn
    1COOLVX
    [QUOTE=Doc4h] About the only bad thing I could see is if some one new you had it and wanted to mess with you they could drain your oil easily.
    ..Like you said; all it would take would be some smart little *** to pull the plug on your motor.
    Other than that it's a fantastic idea...I'm going to check it out too.
    John
    The dealer may claim that installation of this drain plug led to excessive oil consumption and subsequent bearing failure.
    Take it off before you take it in
    Not if you replace it with the stocker b4 the dealer sees it
    May 2003
    '99 Astral #1613
    If their website is telling the truth, the dealer can't say a thing...
    Endorsements:
    The Engine Oil Drain Valve has been tested and granted "Genuine Parts" status by 6 major motor vehicle manufacturers in Japan, including Toyota, Nissan, Mazda, Mitsubishi, Subaru and Isuzu. These approvals were not granted easily and gaining them was a testimony to the quality and durability of Engine Oil Drain Valve. In the United States, the Engine Oil Drain Valve is being installed at the factory level on some of the vehicles/equipment made by Ford, Kohler, Freightliner, Caterpillar, JLG, GEHL, Ingersoll-Rand, Sullair, Toyota, Case, Magnetek, Timberjack, Lincoln Electric, Vermeer, Baldor, Terex, Deutz, Phaser Marine Generator and etc.
    Nov 2002
    Lightbulb
    Folks, keep in mind for the event some trickster dumps your oil that if you don't notice the 5-quart puddle under your truck you should notice the oil warning lamp staying on. If you miss those two things, well, you probably deserve the rest.
    NOTE: The nice thing about the Fumoto valve is that you can also safety-wire it in the closed position if you desire.
    Feb 2003
    nothing ever gets close to hitting my oil pan, much less the bolt...as I have the diamond plate steel skidplate. and with the fram oil drain it has a protective screw on cover and also you have to have the cover removed and the hose screwed on which releases the oil.
    Nov 2002
    Question
    Spazz, if you lose or misplace the 2nd piece to that Fram get-up can you still drain the oil?
    Is the 106N the correct size?
    Thanks, Roy
  1. Hood Drain Hole
    Last Post: 01/11/2014, 06:35 PM
  2. How to drain power steering
    By VXNIT in forum VX Talk...
    Last Post: 10/02/2010, 06:48 PM
  3. where is PCV valve located, and how do i clean the valve tube?
    By CoastieCosta567 in forum General Tips...
    Last Post: 05/14/2007, 10:33 AM
  4. 15k tranny drain vs flush?
    By WyrreJ in forum VX Troubleshooting...
    Last Post: 09/27/2004, 09:15 PM
  5. Oil Drain Plug Help
    By DeafVX in forum VX Talk...
    Last Post: 08/16/2003, 12:11 PM
