Results 1 to 15 of 18
Thread: Oil change concerns..Air filter?????
    Apr 2003
    2000, Dragon Green, 0808
    I have been considering going to synthetic for about 3 years. I just had trouble justifying triple the cost of oil. Well, my beast rolled over 65K miles this month, so I made the switch.
    VXNIT - No issues with switching to synthetic. Some might argue, but I would not say that you are committed to it from here-on-out. You could switch at any time. However, I would recommend sticking with one oil over time. Only reason I say that is because some oils do not mix so well, and can cause gunky build-up if mixed. Penzoil was notorious for this.
    Back to the oil weight question: So I should maybe use 20W30 in the summer, and 5W30 in the winter? I live in Missouri where we have 95 degree summers, and 20 degree winters. Let me know what you all suggest.
    Thanks,
    May 2005
    '01,Firefox
    Whoa there! The fram filter idea might not be so good. According to some research I did a couple months back, Supertech filters sold at Wal-Mart for $1.97 out-performed the fram due to a heavier duty by-pass valve and better filtering media. Also according to this test, Wix and Purolator or the equivolent Napa Gold filters were a couple of the best. Regarding oil who knows. I've seen some pretty crazy test results and have wondered what to run. A friend suggested valvoline 0-40 as it tested better than mobil 1 but I haven't taken the plunge yet. I also belong to a grand prix forum where the boys send samples back for testing on a regular basis. Mobil 1 does rock but the valvoline seems to protect the motor for a longer period of time.
  1. Replies: 7
    Last Post: 02/24/2007, 10:06 AM
  2. Transmission Fluid Filter Transfer Case Fluid Change
    Last Post: 09/16/2005, 03:23 PM
  3. tranny filter change 30k service
    By xiaoz in forum VX Talk...
    Last Post: 01/06/2005, 08:55 PM
  4. S/C concerns?
    Last Post: 09/26/2004, 07:14 PM
  5. Air filter change
    By cooks 7 in forum VX Modifications...
    Last Post: 10/03/2003, 02:27 PM
