Results 1 to 9 of 9
Thread: High pitch whistle
    Jan 2004
    '01 Kaiser silver 0729
    Arrow High pitch whistle
    I just noticed a high pitched whistle comming from my engine compartment when I accelerate sometimes. It sounds alot like a turbo spooling up, I'm thinking it might be a leaky intake manifold gasket. Any other thoughts from you guys?
    Feb 2003
    mine makes a whistle at around 70MPH or more when on the highway...but that is with my 305 70 17" Goodyear Wrangler MTR's and the speedometer is not calibrated a ssuch, so it is accually going much faster than what it says.
    Jan 2004
    My whistle is defenitly not wind related because it happens at any speed. As long as I'm accelerating it makes a air sucking whistle noise, if I let off the gas it stops.
    Feb 2003
    mine is not wind related either. It happens at that speed I mentioned as long as I have my foot on the pedal. If I take it off the Pedal, the sound stops, accelerate again and the sound comes back.
    1999. silver 3254
    Hey Guys
    I have had that problem once. Its the PCV valve.
    Jan 2004
    Now that you mention that I do have a little diesel sound comming from the engine too. I guess it's about time to check and clean the PCV and ERG valves.
    May 2005
    1999/White-Ironman-0648
    Smile whistle
    Could be the oil filter believe it or not,my was making a high pitch sound,could hear while in park very well i assume going down the road as well..change the filter and it was gone!!
    From The Mind Of Lashsquat
    May 2004
    No VX anymore. :(
    It's your air intake. My morgantec intake whistles at specific speed / rpm /throttle combinations
    Steve
    2000-Ironman 0219
    Make sure the nut which attaches the pipe to the bottom of your EGR is tight. Takes a 22mm open end to tighten, a little ackward. This one if loose, will produce a diesel sound. Many posts on that subject by fellow VXers.
  1. High Pitch Noise associated with keyless entry?
    By logan1079 in forum VX Troubleshooting...
    Last Post: 01/14/2009, 07:51 PM
  2. High pitch whine on idle
    By Yefim in forum VX Troubleshooting...
    Last Post: 02/07/2006, 07:41 AM
  3. Factory keyless entry indicator (high pitch beep sound)
    By Moon-machine in forum VX Troubleshooting...
    Last Post: 10/12/2005, 10:30 AM
  4. High pitch whine at 60+
    By PBR in forum VX Troubleshooting...
    Last Post: 04/03/2003, 06:42 PM
  5. High pitch noise even when NO KEY in the ignition - any ideas??
    Last Post: 12/18/2002, 09:52 AM
