Notice one upper and two lower bolts to remove. Quesytion is how do you get to heads of two lowers? I am going to reattach my gaskets and not sure how to get to those two bolt heads...
Make sure you are talking about the bolts in the front of the housings. The backs are for adjustments.
To get to the two lower bolts on the front, it's easiest to take the front cladding off. You'll be surprised how short the front really is.
Scott / moncha.com
Thanks Scott, Wow! seems like a real pain to just reomove a headlight...Not surprising however...
This shot may help you.. It came from my Fog Light Upgrade
Click the thumbnail
i removed mine without removing the front cladding. don't remember exactly what i did, i will look at them in the morning and let you know. shawn
1COOLVX
You can by reaching under the lights in the hole that is to the insode fo the light housing, but I found I came up less scarred by taking off the cladding.
Thanks everyone, clearly they made it somewhat difficult for us. Thanks for pics and feedback.
