Were is the transmission dip stick? I'm baffled. please help.
TARHEELUNC-ROSS
you must have vx in park and started and undo the tranny fill bolt and pump fluid in there untill fluid comes out, then shift thru the gears and then fill again till fluid comes out..oh yeah, don't drive it first or pressure will put your eye out
SO TRUE...........and man did I drive myself VEHIcrazy looking for one too!!
This has to be the biggest blunders on the VX design (*besides the window problem).
John
My transmission fluid is visibly black. Is this not something that the dealer typically does? They haven't brouhgt it to my attention the last 3 visits. Or are they waiting for my transmission to fail?
I think the manual gives 60k or 100k before having to change the fluid under normal conditions. Mine has 45k?!?
I am getting ready to change my Trans. fluid and filter out at 54K. I'm not waiting for the old ticker to turn 60K![]()
John
This is from the VX repair manual. I've had my tranny serviced twice so far. Frequent fluid changes are always a good idea, regardless of the maintenance schedule.
I would change the xmission filter & power flush this puppy without delay, right now!Originally Posted by CSTYLES
I don't know why, but this quote had me laughing for 10 minutes. Maybe it's the visual.Originally Posted by SPAZZ
What do ya'll think about swapping the pan with a dipstick capable 4L30 pan'd vehicle -like a Blazer or E36 BMW? Why'd Isuzu go with a sealed unit anyways? Is there something special about this particular tranny?
Originally Posted by mbeach
probably to keep dirt or stuff out of the tranny....?? tats wat i always thought
________
Web Shows
If that were the case, all automatic cars would not have dipsticks.Originally Posted by MZ-N10
Heck, my WRX had a dipstick on a manual transmission -and that car was built for rally.
I'm sure that there's some bureaucratic reasoning at work here, no engineer worth his calculator would design a transmission that was impossible for the user to check the condition of.
...Or maybe it's because of where the tranny came from...Originally Posted by MZ-N10
Isuzu uses the 4L30E type transmission built by GM of France![]()
I guess they figured "If you have one...you are one"
John
I think it is the French trying to stick it to us again....![]()
LOL...
Fransmission
Seriously, do we share a pan configuration with another 4L30E car/truck. I'm all for swapping it out when I do my next service.
Check a bmw z3, same tranny in there.Originally Posted by mbeach
Don't get your hopes up: the dipstick doesn't mount to the pan. The dipstick mounts through a hole in the top of the cast section of transmission that the pan mounts to.
http://tad.grosvenor.org/gallery/94TrooperMods/CIMG1427
Looking at that photo you'll see the output for the transmission cooler at the front of the middle section of the transmission. If you look at the 1994 transmission behind it, you'll see an oil black hole there. That's where the dipstick connects to the transmission body. The newer (1999) transmission doesn't even have a non-drilled depression there. So the best that you could do is to remove the transmission, drill the case and hope that it seals. There also might be a difference in the valve body inside the pan there as well, I don't remember that part.
Be sure to keep the later non-dipstick pan too. The earlier pans didn't have a drain, so changing the fluid was very messy. I ended up sucking the fluid out with a topsider instead of trying to lower a pan full of fluid.
-Tad
