Results 1 to 14 of 14
Thread: Fails to Idle
    Fails to Idle
    OK, so now I've got a problem.
    Suddenly, with no tinkering or new mods, the engine will not stay running at idle this morning. You can wing the throttle and she revs smoothly. You can drive away and not feel or hear anything amiss. When you stop it may idle at about 1200 rpm or it may die in or out of gear. If you restart, it dies over and over.
    I have codes of P0171 and P0174 which are FUEL TRIM SYSTEM LEAN BANK ONE AND BANK TWO, respectively.
    I have had a code P1441 for a long time. It shows EVAP SYSTEM FLOW DURING NON-PURGE. This re-codes in a few miles after clearing. I do not think the 1441 code is related to the current problem.
    Last gas fill gave the usual 15.5 mpg.
    Thanks for any ideas or advice? Yes, I am supercharged.
    2000 Dragon Green VX 0485
    Sounds like a Vacumn leak to me. Make a good visual - CK PVC at valve & rear of Plenum also EGR connection at back of Plenum also Vacumn line at throttle body and at fuel regulator (Fuel rails Driver side rear).If all else fails spray Carb cleaner with engine running at intake manifold gasket mating services if RPM rises Try tightening manifold, if that fails new Intake Gaskets req. order
    PN 8-97237-538-0 two req at $18 + each - 1-800- 727-8066 ask for Merlin. S&H is free
    Torque value is 13 FT LBS on all intake manifold nuts & Cap Screws.
    Bob is spot on with the advice.... prolly intake gaskets.
    face the mirror
    At some point you'll have to address the evap problem. I seem to recall mention of a purge solenoid problem. That may require a trip to a dealer to confirm.
    I'm leaning (no pun intended) toward the intake gaskets for the other problem, but the codes seems to indicate too much air or too little fuel. Start your diagnosing with that in mind.
    2000,silver,vehicross,0460
    The codes showing banks 1 and 2 lean are the same ones I had. I also had problems with idling, including the engine dying out. After changing my intake manifold gaskets, they went away and everything was perfect.
    Todays progress --
    Inspection provided no joy. All vac hose connections are soft and well seated. Flexing hoses with engine running made no difference in idle.
    Without removing fuel rails, I could only check tightness on three of the eight intake maniforld bolts/nuts.
    I used this time to replace the S/C nose and get rid of the damn rattle. Fixed.
    I visited the local garage with all of my info and codes. They put on a vac guage and said it was steady, thus no vac leak. I am not sure that is a meaningfull test, but their position is that I must go to Isuzu for a deeper diagnostic. No charge for an hour's work, but problem not solved.
    I called and ordered intake gaskets. Merlin at St. Charles, says a new replacement part number is on hold to fill many back orders. 27 are in some warehouse and I had to give the VIN number to get expedited access to the parts. If I am lucky, it will take a week. He mentioned this engine is in the Honda Accura and many other models. All are/will have intake gasket problems and the new gasket part number is aimed a solving a wide problem. So much for Japan quality.
    When I get the gaskets in hand I will visit the Isuzu dealer 2 hours away and camp out until fixed. Maybe they can fix the 1441 code at the same time.
    Thanks for you help. Roy
    2001,Ebony,VehiCROSS,1092
    I was getting the same codes as you, but not having an idle problem. The ck eng light would come on, stay on for 1/2 day to 2 days and then go off, only to come back on in a day or 2. Finally, it came on and stayed on for several days. Took it to the dealer, they pulled it in the shop and it went off! Said they checked it out thoroughly, including driving with a monitor plugged in - could not get it to read out of spec. So they tried the carb cleaner routine to check the intake gasket - no problem there either. Got 1/2 block from the dealership, and the light came back on. It was finally narrowed down to a faulty aftermarket PCV valve. It was not one piece as it appeared, and the top portion was separating from the bottom. I stopped on the way home and bought one that looked like the original grey one - no ck engine light for a week so far! just a thought if you've bought an aftermarket PCV
    I put on an OEM PCV valve today and it has not helped. Forgot to mention it.
    Thanks, Roy
    Quote Originally Posted by newthings
    Todays progress --
    The part # has not changed and I was unable to tell the difference between the old & new intake gaskets. Since I just had my SC completely rebuilt, I changed the Intake manifold gaskets as well. I had two new sets delivered one each this past Thursday & Friday. One set that Merlin got for me from a local Isuzu dealer & the other from isuzu in Cincinatti.
    E mail me your address. I will try & overnight you a brand new set of intake manifold gaskets.You can return a new set to me when you receive yours.
    Please exhaust all other possibilities before undertaking this task on a SC VX. I found at times I wished I had Three hands + mine was the prototype so maybe yours will be easier.
    Bob F
    May 2002
    2000, Proton Yellow, VX, 0584
    Bob, that is a very kind gesture! Thank you for all of your support and input, you are truly invaluable!
    Scott / moncha.com
    Yes it is.
    E-mail sent
    Roy
    PROBLEM SOLVED
    Thanks Bob for the gaskets. Isuzu sent me a pair that also arrived today. We have the market cornered. Yours will be back in the mail tomorrow. Many thanks. If I can ever be of service to you or the group, let me know.
    As to the solution to my idle problem--
    The EGR valve sits on an aluminum block which is attached in two places: A metal vacuum tube coming from the back of the intake plenum and a flat metal bracket which bolts to the S/C intake manifold. A 1 1/8" spacer is between the bracket and the manifold. A bolt goes down the center of the spacer.
    The bolt hole in the intake manifold goes clear through into the air path.
    So, if the bolt falls up (!) and out of the bracket you have a 1/8" air leak and everything looks fine. My searching with starter fluid spray produced inconsistant results since I was squirting in the wrong places. I pulled off the EGR and replaced the gasket. When putting the valve back on, the spacer fell over. A search for it's home revealed the hole.
    Since I have the appointment with the dealer all set up, I will get the 1441 code fixed finally.
    Thanks for the support.
    Roy
    Quote Originally Posted by Green Dragon
    Well speaking for myself " Even a blind pig picks up a few acorns once in awhile"
    After a brief respit from idle problems and codes, the problems returned. Zipping under the hood with wrench in hand I found the EGR bracket bolt tight! Dang. After the vac hose check and spray with carb cleaner drill, I could not find a leak source. Another 2 hr. trip to the Isuzu shop finely got results. They felt it was the intake gasket in the front area. Hmm, the codes say lean in both banks. Both gasket leaking? So off came the S/C and manifold. New gaskets and the same problem returns. Then the search goes to the back on the S/C chamber in the back next to the firewall. Another drilled through threaded hole holds on a bracket for the fuel line. The bolt is loose and inaccessable. Off comes the S/C again and the the bolt is LockTited in place. Problem solved, at last. Two different bolt leaks and two different fuel line leaks in a few months has been a nasty exercise.
    As to the 1441 code I have had since the S/C went on. The tech said a vacuum line from the back of the S/ C went to the evap control system, but it should go to the orphan plastic switch mounted on the front of the engine. Alpine just capped it off. The tech said the evap system cycles on and off and should not have continous vac. Hose added and port capped. Problem solved.
    Roy
  1. VX Idle Issues
    By CatFish in forum General Tips...
    Last Post: 04/29/2017, 07:40 PM
  2. Fast idle, low idle, (stalling) temp gauge all over the place.
    Last Post: 11/07/2016, 09:48 PM
  3. OBD not ready and Fails the inspection
    By DLNTHO in forum VX Troubleshooting...
    Last Post: 04/10/2013, 12:28 PM
  4. Another Idle issue
    By housertl in forum VX Troubleshooting...
    Last Post: 09/27/2011, 07:29 PM
  5. idle
    By cascabel3 in forum VX Troubleshooting...
    Last Post: 12/17/2004, 09:30 AM
