I've got a pretty loud noise (sort of a howling) from the belt drive when I start up on a cold morning, it goes away after 10 minutes of driving. I'm quite sure it's a bad bearing in a pulley (I've ran into this before on another vehicle).
I started the engine with the belt off for a few seconds and noise wasn't there.. I've replaced the idle pulley and tensioner pulley and a new Gatorback belt because it was a cheap way to start diagnostics- no luck noise still there. So that leaves the water pump and the power steering pulleys (It really does sound like it's coming from the power steering pulley). Before I try and replace those, I was wondering if anyone has ran into this noise and how they managed to fix it.
A few more questions:
Anyone have any recommendations or otherwise for aftermarket water pumps (a good quality one)?
Can I replace the pulley on the power steering or is a bigger assembly that I have to get?
Thanks for any advice.
Ken
