Results 1 to 5 of 5
Thread: My CF vinyl amp rack...
    Got around to snapping some pics of the sub (enclosure) & amp rack I built last summer.
    Enjoy:
    -biju
    '99 Ebony VX #0038
    Looks nice. Does the amp rack have a cover?
    fab'ed? fabbed?
    Actually - that was in my original plan - to have a cover that sets on top (matching CF vinyl) designed for airflow/convection, etc. However, I discovered that I *rarely* use the back end if ever to carry stuff. If I do need to put anything in the back, I usually just recline the back seats backwards and slide the bags/goods onto the seats. I don't know, works for me...
    I fab'ed the two tier rack (bottom hides wiring, top displays amps) so that it's bolted down by all four holes in the rear floor. Two bolts are under the amps, which in turn are secured by special hardware screws (not easy to remove for the goblins out there...). The lid then props up on a hinge to expose the other two bolts towards the rear end.
    Over all it's pretty clean and secure.
    0 & 4 gauge power/ground wires.... Brushed steel bottom covered by plexi which is what the amps rest on....
    The stitching was only $120 done by DMUD (dmud.com) here in Denver.
    -biju.
    1997,Silver
    Excellent mod....
    What did you use as the guts of the design? (Wood/fiber glass??)
    Care to share your design.... me want one too....!!!!!
    Thanks
    Ameet
    An angry man is seldom reasonable, a reasonable is seldom angry
    1999, sliver, vehicross 0782
    the rear door subwoover, do you need to take off the spare tire?
    and is it hard to built that amp rack?
    very nice mod!
    blue HID head light, custom license plate "GOVEHIX", Pro M mass air flow, black safari light bar from Tone, PIAA 194 fog light intalled, PIAA 550 fog light lamp installed, custom bull bar extention installed, Levoc ultra metal pedal set, Bioharzard sticker at the rear glass, Recaro red cellphone holder and razo steer cover.
    Occupation: Full Time VX Driver
  1. Idea for Paint/Vinyl Wrap
    By SomeoneElse in forum VX Modifications...
    Last Post: 05/07/2013, 06:02 PM
  2. Kaiser gets a vinyl face lift!
    By Knigh7s in forum VX Modifications...
    Last Post: 09/22/2008, 03:05 AM
  3. Vinyl Decal on Hood Insert
    By tysamigo in forum VX Modifications...
    Last Post: 04/22/2007, 11:48 AM
  4. Diamond Deckplate mod (Black Vinyl)
    By wekilled in forum VX Modifications...
    Last Post: 03/11/2007, 01:03 PM
