 Originally Posted by
bigdogdeee
				Leaking Exhaust
A leaking rear wheel bearing
A leaking rear shock
An engine burning oil at the rate of a quart and a half every 700 miles
A non working cd player
Leaking Exhaust---This is something that can/will occur with any car you buy...and if it is just the muffler you can go with any number of aftermarket companies that would be cheaper and lighter than your original. (i.e. MagnaFlo, Flowmaster, used PV...etc.)
A leaking rear wheel bearing---This doesn't seem like a common problem so unfortunately you'd have to bite the bullet on this one and if you could swing it I'd look into having both done for insurance.
A leaking rear shock---I had a leaking rear front and lucked out getting both fronts changed under factory warranty @ around 23k miles...but for the price of replacing one original shock with a new stock one you could probably pretty much replace all of them with any number of aftermarket ones people have tried at this site...use the search...I'm personally leaning towards the Bilsteins if I can't swing staying with the originals (which I love!)  Also...Rancho 9000 adjustables offer a softer ride if that is what you crave as described by those who have them.
http://www.drivewerks.com/cgi-bin/pp...Shock+Absorber
A non working cd player----small potatoes...drive it until you can afford an aftermarket one as there are many options here.  At least you have a radio with cassette.  I couldn't see trading in any car over a cd player!  I just bought a '95 Monte Carlo Z34 without one...oh the pain...lol.
An engine burning oil at the rate of a quart and a half every 700 miles---okay...this is the "biggie" as it could be a real big cost to replace engine...try replacing the PCV valve (Deutsch brand) found at AutoZone (Theirs seems to fit better than the Purolator from Advance Auto) as this is a two minute job if you've done it before; and plan on changing it every other oil change for insurance (costs like $3) and take your EGR Valve off (2 bolts and unplug) and spray it out with carb cleaner (Oxygen sensor safe) and also flush out the EGR pipe after Valve is off...(job takes about 1/2 hour maybe if you've never done it before) and reinstall.  If you get a check engine light (I didn't) than unplug battery for 30 sec or more and reconnect (unless you have a code reader that removes codes).  Drive normally and observe oil usage to see if it minimizes (mine used alot one time...did all this...now it barely uses any in 3,000 miles)
