Results 1 to 9 of 9
Thread: Question about the wiring harness for fog lights
    2001, White (IRONMAN), VehiCross, 0201
    Question Question about the wiring harness for fog lights
    I am trying to find out if the wiring harness on a 2001 model VX is already equipped for fog lights. The service tech. at my local ISUZU dealership is going to order and install the lights for me , but he said that he needs to know if it is already wired for it. Also, does anyone have ISUZU stock fog lights and are they any good?
    Arachnid J
    Titusville,FL
    '01 Ironman VX
    #0201
    Sorry, it is not - no provisions were made for this, However, you can add PIAA1200s in the location of the round indicator lights and the electrical connections are simple and easy.
    2001, Proton Yellow, #0580
    Cool Lights in the Rear Reflectors
    Anyone thought about mounting lights where the rear reflectors are mounted? I had the bumper cover off and there's plenty of room back there... thought some bright back up lights would be great!
    -- John
    Thanks, Tone. You are the man with the answers.
    May 2002
    2000, Proton Yellow, VX, 0584
    Another option for front parking lights...
    Here's another option for replacing the front lights.
    To find them go to www.hella.com and look for Micro DE auxillary lighting.
    Scott / moncha.com
    `99 Astral Silver #1327
    PIAA recently discontinued the 1200's but I recall from previous research that the 1100x Platinum's have the same dimensions. However, these are driving lights and not fog lights.
    I recently ordered a set of the PIAA 520 SMR fog lights to mount on the safari bar I bought from Tone. I plan to either buy the 1100x's and mount in the stock marker light location, or attempt to fit another set of 520's (the driving light model) on the safari bar between the 520 fogs. But, I'm not sure if the latter is even possible, has anyone ever tried it? I wonder if it would even look good.
    Quote Originally Posted by johnnyapollo
    -- John
    Been there done that. If anyone else does it I recommend using lights with faceted reflectors as the recess on the cladding cuts out much of the side lighting.
    Feb 2003
    2001's are not equipped for foglights...as I own one and I was not happy when I purchased mine and found this out since Kelly Blue book and all other sources for advertisement and info said they did.
    Isuzu meant for this but GM cut cheaper corners...also like the 4" rear speakers...and not to mention a $30,000+ vehicle with a rodeo dash...and the short cut as using the 3.2 engine with 3.5 ported heads to say it is a 3.5, but that gets horrible mileage and the rodeo transmission that loses too much power and does not perform as well as it should.. The Trooper has the true 3.5engine, is way heavier, and gets better mileage. I know some of you have sold a VX to buy a Trooper for the better mileage.
    Spazz you never cease to amaze me! The engine is the same between the Trooper and the VX- they are both stroked 3.2L with true 3.5L internal combustion areas. Gearing is probably diffferent between the Trooper and the VX if your mileage differences are true and the 2 vehicles are meant to be driven way differnently. If anyone bought this (or any other SUV for mileage) you bought the wrong one! I have yet to hear of Porsche, Ferrari, or Lamborghini owners complaining of mileage....or visibility concerns.
  1. Right side O2 Sensor wiring/TOD wiring harness proper locations
    Last Post: 07/27/2013, 11:32 AM
  2. Wiring harness for VX
    Last Post: 04/10/2011, 11:34 PM
  3. Wiring harness for stock stereo
    By CrnCnn in forum VX Modifications...
    Last Post: 02/05/2008, 05:47 AM
  4. Wiring Harness Pioneer DEQ7600
    By VXD959 in forum VX Modifications...
    Last Post: 08/06/2006, 09:36 AM
  5. Radio Installation - Wiring Harness
    By -x- in forum VX Modifications...
    Last Post: 04/28/2003, 07:17 AM
