Results 1 to 3 of 3
Thread: Just installed adjustable Ranchos - what fun!
    Mar 2005
    01 Ebony - #0379
    Oh what fun!
    Actually it was quite painless, bolts came off quite easily.
    However, I did curse a bit at that top bolt on the rear, lots of wiggling to position it right to pull it out all the way to get the shock off. (Developed a new curse "Shock Off!, Shock off!").
    I can't play with the settings yet, as I only have 3 of the 4 installed. The last rear Rancho I was about to put on was defective - the rod pulled right out of the tube when I was putting the boot on. sucks.
    Here's a few snaps if anyone's curious about them.
    FRONT:
    REAR:
    I thought the Rancho front bushings were a bit pitiful compared to the stock bushings, so I re-used the stock - Comments? Bad Idea? ...
    --Ken
    Last edited by Moncha : 04/16/2005 at 05:30 PM Reason: Posted medium image instead of large
    '99 Astral #1977
    I installed my Ranchos last weekend. You're right about the top of the rears being a pain. It took me longer to find a breaker bar and wrench slim enough to fit in the limited space than it did to actually install the rear shocks! Plus I had one of the front shocks' lower bushing siezed onto the bolt. That was real pain in the ***** to break loose. I hate when when you need tools or parts and your only mode of transportation is down and it's 8:30 pm.
    I used the new bushings up front. I really don't think it matters. I had them, so I just used them.
    RichD
    Rancho bushings are better - polyurethane over rubber any day.
  1. My Indy 4x4 Adjustable Rear Links just arrived........
    By JoFotoz in forum Chit-Chat ...
    Last Post: 03/07/2013, 07:08 PM
  2. AutoTrans Interceptor Adjustable Electronic Shift Kit
    By stt9c1 in forum VX Modifications...
    Last Post: 05/05/2011, 05:46 PM
  3. Rear Adjustable Coil Spacers
    By bmrchad in forum VX Modifications...
    Last Post: 07/08/2010, 09:32 PM
  4. Height adjustable air system.
    By kodiak in forum VX Talk...
    Last Post: 05/22/2008, 03:10 PM
  5. PV installed
    By DamN in forum VX Modifications...
    Last Post: 11/12/2004, 03:23 PM
