Greetings all!
New to the forum and have a question.
I just moved to Houston and drove my 2000 VX (aka: Suzie, my girlfriend named her) down from Connecticut. I have owned Suzie for about 2 years and she has had most of the typical problems (CD player, headlight gaskets, wheel peel, etc).
I just hit about 85000 and this morning my check engine light went on and she is idling real rough. Jumps from about 200 rpm to 1500. Sometimes she will smooth out and other times she may stall. Went to Autozone and they gave me the codes po171 (lean on bank1), po174 (lean on bank 2), and po303 (cylinder 3 misfire). Any suggestions....I am heading out to jiggle wire harnesses, check vacuum lines, and do all the other basics. Wanted to check if anybody had any experience with these codes before I call the shop.
Also, any VXers in Houston?
Thanks,
Adam Rapp
