View Poll Results: Did you file a complaint on the "Window Problem"
Voters
37. You may not vote on this poll
  • I filed online
    35 94.59%
  • I filed offiline
    2 5.41%
Page 6 of 6 FirstFirst ... 2 3 4 5 6
Results 76 to 87 of 87
Thread: File Your Window Complaint On Line
  1. #76
    Feb 2005
    2001 Ebony VX 0448
    Your Complaint Information is successfully submitted.
    Your Confirmation number (ODI Number) is: 10127712
    Passenger side window is starting to bind, groaning and straining as it goes up, 39000 miles.
  2. #77
    Dec 2004
    2000, GREEN, UT,0782
    Quote Originally Posted by scarpezio
    Give both sides a good spray with silicone lube. Make sure it runs down into the track inside the door. It will reduce the friction to almost zero and prolong the use of the windows.
  3. #78
    Sep 2003
    2000,Firefox,VX,0458
    Smile Filed my complaint.
    Got my VX back from service a week ago and the service guy's exact words were..."You made out!"
    Damn straight.
    I had a bunch of warranty work covered. Rear Axle bearings replaced. But check this out...the window regulator was replaced ($81.48) and the motor for the window. ($182.32) A total of $357.40
    All covered by my warranty. Why am I telling you this? So, anyone who is having to pay higher than that is getting ripped off!
    Even though my defective windows were covered...I went ahead and
    filed the window complaint online. Confirmation # 10127827
    Now, hopefully the driver's side window will stay intact.
    This is the fourth time the window(s) have been fixed.
    Maybe I'll change my mind by the time my lease is up and buy the damn car, after I had all this free work done on it.
  4. #79
    I hope it works
    Your Confirmation number (ODI Number) is: 10145127
  5. #80
    done
    Your Confirmation number (ODI Number) is: 10145131
    -biju.
  6. #81
    '01 Ironman
    VOQ Confirmation
    Your Confirmation number (ODI Number) is: 10145142
    I CAN'T BELIEVE I DIDN'T SEE THIS THREAD BEFORE!!!!!!! Why did the poll close?
  7. #82
    Mar 2004
    99, Silver, VehiX 1667
    Angry Help
    Tell me where I file my window complaint... mine hasn't worked right in a year. I gave up going to the dealer the never solve the problem. I just quit using the passenger side and when I use the driver side I have to help it up with one hand.
    Ed
  8. #83
    Mar 2004
    Got it!
    Your Confirmation number (ODI Number) is: 10145400
    Having the dealer replace the window motor and regulator doesn't solve the problem! I have had mine replaced twice.. it is only a temporary fix. The tracks need to be modified to really fix the problem. Hopefully our complaints will get some action.
  9. #84
    Dec 2004
    Quote Originally Posted by Edward
    Go to the first page of this thread. I put the link there.
  10. #85
    2000, foxfire red, 0474
    Just filed. Hope it works.
    Max.
  11. #86
    2001, Kaiser Silver, #988
    Sorry to dig up and/or hijack an old thread, BUT...I have to for two reasons.
    1) Did these window complaints ever get anywhere with the ODI NHTSA??
    2) Also, I would encourage any and all VX owners who are reading this and have had their ABS module fail to STRONGLY consider filing a complaint through the same site noted in this thread. You can do it online at http://www-odi.nhtsa.dot.gov/ivoq/ or by phone...takes 4-5 minutes...you'll need your VIN# and have to give some info leading up to how you discovered the problem, etc. I just did it, because paying a dealer around $3,000 to fix something safety related that should last AT LEAST over 100K miles on any vehicle is silly and wrong. I have also confirmed with a technical person I called on within Isuzu in CA that without a properly working ABS under severe/extreme flat/pedal-to-the-floor braking, the VX's TOD (which does receive data from the ABS system in how the TOD operates) may be effected and may put drive torque on wheels that aren't responding meaning instead of stopping you'll continue with erratic drive movement forward. I did get the feeling though this was a worst case scenario, but, imagine that causing or happening in an accident. Clearly there is a design or manufacturing defect with our ABS and when I called Isuzu customer relations, they simply say pay the money to have it fixed and have a nice day. Please, consider filing a complaint. It may make a huge difference in us getting a deserved repair.
  12. #87
    bump!
  1. Line-X'ed the Vx
    By ssignature in forum VX Modifications...
    Last Post: 04/22/2013, 10:13 AM
  2. Window Issue - Regulator and Window Strip
    Last Post: 01/13/2009, 11:31 AM
  3. submit a VX complaint
    By azskyrider in forum VX Talk...
    Last Post: 06/27/2004, 09:52 AM
  4. Drive Bad - Crash - File Lawsuit
    By t2p in forum VX Talk...
    Last Post: 06/05/2004, 05:51 PM
  5. Mileage "non"complaint
    By Ron Pfeiffer in forum VX Talk...
    Last Post: 04/06/2004, 08:51 PM
