if it is a bolt you can get to with a torch you can get it loose pretty easy.heat the bolt until it is red, then apply wax to the threads.a candle will do ,just touch it to the threads and the heat will suck the wax into the threads and free up the bolt.it may take a couple times but it does work i have used it many times at work. shawn
