Results 1 to 15 of 20
Thread: VIBRATION !,Any ideas?
    Arrow VIBRATION !,Any ideas?
    So here's the deal,
    I had an acci. this winter, tangled with a tree & crunched r/r 1/4 panel...it also snapped the weld on the bar from the frame to the axle housing moving the right side of the axle back far enough to pull the drive shaft out of the splines.All the bodywork etc. came out perfect but...after replacing the axle,axle housing,suspension links & entire driveshaft,there is still a vibration.
    I replaced all 4 tires & the rim is straight & they all balanced up fine. After replacing the axle housing, the alignment came out spot on.Between my bodyshop guy, mechanic & myself, were running out of ideas.
    Anyone have any ideas...even longshots, on what could be causing this?
    Any & all help is greatly appreciated.
    TIA, Ldub
    Arrow
    Was the TOD Box checked while you were doing all this? And was everything put back to original specs?
    John
    John,
    Not sure what you mean by orig. specs. I don't have a lift or anything aftermarket going on w/ the suspension,so stock alignment values were used.
    The TOD/ transfer case is probably the next logical place to look. Unfortunately, the nearest dealership is either Bismarck or Minneapolis...both 200 +/- miles from Fgo.
    Thx for the input, Ldub
    Arrow
    OK,that rules out the modification angle...so that's all factory.
    Next step would be to check any mis-alignment to the TOD transfer case and alignment if the shafts to that case. Just my two cents.
    I know it's a pain(and sometimes frustrating and costly) to head for the ZuZoo dealership, hopefully you have an honest dealer there in the area. If not try a 4 wheel drive shop/mechanic.
    John
    Thanks for the input John, monday it goes in to get the drive coming off the trans. ckd. w/ a dial gauge. I guess all we can do is start at the back & work fwd. I'm fortunate that my ins. co. OK'd all this extra work...so far.
    Ldub
    Arrow
    Good luck Monday!
    Don't forget to have them dial in the Drive shaft tubes as well.
    John
    Thanks Bear, this "project" has been ongoing since the first of the year & I'm more than ready for it to be done.
    Ldub
    If you tweaked the frame out of square it could put the pinion angle out of alignment. That would cause vibes too. I imagine you've already thought of that though.
    Its the thrill of the chase
    S words for a thoosend Alex,
    Sorry man,my mind is wandering as the mercury drops & the sky goes grey.
    Ahem...Thanks Swordy,I appreciate the response, you are correct, I asked the body shop guy who initially had it on the frame rack & the alignment tech. who did the alignment if the frame got tweaked...both responded negative.
    I appreciate any & all ideas on this, hoping it's something that was easy to overlook, but I have my doubts...
    Ldub
    '99 Astral #1977
    If the wreck pulled the drive shaft out, maybe the drive shaft is bent or out of balance? Maybe U-joint? Or bearings?
    *edit* just re-read your post to see you already replaced the driveshaft.
    RichD
    Just becaue a part is "new" doesn't mean it is straight or in balance. You might still want to have the drive shaft and other new parts checked. I've had many new parts that are bad from the box.
    Good point,Thanks Billy & Analog.All points of view are helpful in this mystery.
    Ldub
    Let us know how you made out after the visit to the shop...dying to know what they find...if anything.
    John
    The saga continues, didn't get to talk to the mech. after work...all I know is,
    they ordered more parts & when they come in, they'll call me.
    I'll keep ya posted on new progress as it happens...I hope.
    Ldub
    2001, Proton Yellow, #0580
    One more thing to check - the exhaust. The flange is right above the cross member - the impact may have dropped it slightly, causing the flange to lightly touch the crossmember - this would be most noticeable during WOT as the engine torques. Also, the front part of the exhaust on the right side gets very close to the right torsion bar and could be doing the same thing. It's very tight under there and the mere touch of an engine part to a body or suspension part could be causing the vibration (when it's really hitting you'll hear a clanking type noise, but if it's just touching it will transfer the engine vibration). Just something to consider.
    -- John
  1. Drivetrain vibration
    Last Post: 03/11/2016, 05:19 PM
  2. Arg! What's that sound and vibration!
    By Slideways in forum VX Talk...
    Last Post: 08/26/2012, 08:11 AM
  3. Hmmmm......ideas....ideas...
    By JAMAS in forum VX Talk...
    Last Post: 11/04/2009, 12:32 PM
  4. Vibration when turning
    By Shortstop in forum VX Troubleshooting...
    Last Post: 03/13/2006, 06:22 AM
  5. vibration while steering
    By james1_10018 in forum VX Troubleshooting...
    Last Post: 08/10/2005, 07:05 AM
