Results 1 to 15 of 17
Thread: Results on LED testing
    May 2002
    2000, Proton Yellow, VX, 0584
    I asked LEDTRONICS if they'd provide the site a set of LED replacements for the 1156 (Turn) and 1157 (Parking/Stop) bulbs.
    They happily obliged and sent 1 Red 1157 equiv and 1 Amber 1156 equiv for testing. Each is comprised of an encased 24 LED array. 18 LEDS on top facing forward and 6 pointing to the side.
    I put them in and took some pitcures. I'll be doing a complete write up for the Reviews Section here soon.
    Anyway, here's a list of pros and cons;
    PROS
    -- Very cool running
    -- I LOVE the instant on/off ( NO ramp up)
    -- The reds make the taillights match the 3rd brake light perfectly!
    -- Very bright
    CONS
    -- Not as bright from the edges
    -- NOT overall as bright as incandescent lamps (Does not fill the lamp housing with light)
    -- the light IS directional in output even with the side firing lights.
    -- the yellows do not have as bright a glow in the turn signal housing
    -- They are pretty pricey (But, you'll never have to replace another bulb)
    All in all they are not bad. There are differences but it would have to be up to personal choice to see what you'd prefer.
    Here's some PICS for ya and a couple vids.
    #1 showing the difference of the flashers
    #2 Showing the glow that the lights produce
    Scott / moncha.com
    '99 SC Ebony #1961
    Nice...
    So Scott which do you prefer?
    -Dave
    May 2002
    I'm very much undecided at this point. I going to mess with them some more and see.
    '99 SC Ebony #1961
    Yea me too, I bought some blue LED for the horns and they just did not do it for me... ended not even using them...
    Nov 2002
    1999,Astral Silver,0889
    I take it that the ones on the left are the new blubs and the ones on the right are the stock blubs? I just picked up the ones from APC. These have 10 small ones and 1 lg one in the center. I'll try to put them in this weekend and see how they look and I'll post my reveiw with Pics. Keep us posted on how your toying with them works out.
    Tony "TDAWG" Rodriguez
    99 Astral Silver 0889
    I remember seeing some bulbs on the net that had like 10 LEDs in the middle, and something like 10 facing outward around the diameter of the entire bulb. I think this is suppose to direct the light, not only forward, but to the sides as well.
    Apr 2003
    Question Anyone willing to experiment?
    I was wondering how well these LED signals work, especially since they are directional.
    How about taking a very low grit sandpaper and roughen the plastic crystals up a bit? Similar to frosted glass...
    I wonder if that would reduce 'some' of the directionality of the lamps?
    Some (including myself) HAVE experimented since this post. Use the search feature and see what you come up with.
    Feb 2003
    1999, kaiser silver, VX
    LED Bulbs
    I too am interested in LED replacement bulbs, but I have a question. As far as replacing the brake/parking light bulbs... the current setup is a clear incandescent 1157 bulb behind a red lens. I read before that you should match the LED bulb color with the lens cover, but wouldn't a white LED bulb produce a brighter output behind the red brake light lens versus the red LED? Just a thought, but of course, LEDs are too expensive to purchase for experimenting.
    Suprisingly, red leds usually have a higher output than white.
    Feb 2003
    2001, Black, VX, 0781
    leds are dirt cheap, just search on ebay
    Feb 2003
    Replaced bulbs with LEDs
    I replaced my tail light/brake and rear signal bulbs with APC LEDs, and now my turn signals blink VERY rapidly. Any ideas as to why this is happening. All I did was replace the bulbs; I didn't mess with any wiring or fuses...
    Apr 2003
    rapid flashing - due to not enough load in the circut
    A company online called SuperLumination sells a 'load' to attach to the wiring harness to preven this.
    " In many cars, a load resistor is required in each turn signal position to simulate the resistance of the incandescent bulb. Many cars react with rapid flashing or no flashing in the turn signal when you install leds because the led has no resistance and the circuit thinks the bulb is burned out."
    hope that helps.
    May 2002
    I believe that the VX has a thermal style flasher, you should be able to get an electronic flasher from any auto parts store and that may solve your problem. I haven't done so yet but will probably do it soon.
    Sep 2003
    2000, dragon green, VX, 1234
    Post needed for led bulbs
    In what location do I put the electronic flasher after replacing the original signal bulbs with LED bulbs.
  1. MPG Testing AR-5 + 93 Octane
    Last Post: 06/30/2014, 11:42 AM
  2. Testing Waters: VX Wiki
    By Knigh7s in forum VX Talk...
    Last Post: 04/27/2009, 08:28 AM
  3. Update on Morgan-tec S/C kit testing
    By morgan-tec in forum VX Modifications...
    Last Post: 01/28/2007, 07:17 AM
  4. supercharger emission testing
    By Medman in forum VX Talk...
    Last Post: 08/20/2005, 10:43 PM
  5. A Great Car Testing Ground
    By Anita in forum VX Talk...
    Last Post: 11/17/2003, 04:56 PM
