I opened the console and looked at the linkage. on the passenger side there is a blue platic piece that moves up, when the button begins to depress. this piece is stopped by a small metal plate (parallel to the ground) that protrudes from the main "box". i manually pushed this metal piece in to give full range to the blue plastic lever. now it seems to be working fine(will not engage without brake depressed) but im pretty sure it will happen again. i will try to get some pics. should i check the wiring? wd40 if it seems to get stuck?
thanks for the help
dave
