Results 1 to 9 of 9
Thread: cleaning hood of VX
    Feb 2005
    01, Black, VX,
    Question cleaning hood of VX
    i've been using armoral to clean the bottom plastic part of my VX and it works great however when i tried it on the part in the middle of my hood it left it all streaky i was wondering if anyone out there knows of anything to clean that and actually make it look good
    thanks
    amber
    May 2003
    '99 Astral #1613
    First of all I do not use ArmorAll because I heard somewhere that over time it makes the plastic brittle. I do not know this to be absolutely true, but I've opted not to take the chance. Right now I use Meguiar's Gold Class Endurance Tire Gel on the cladding and I'm very pleased with it.
    The hood insert is a hard one to figure out, and I'm still working on the best way to handle it. It just holds that nice look for less time, no matter what you try. This must be because it is more directly exposed and gets a double-whammy of heat from above and below. It is also not bare plastic like the cladding is. I have used the Meguiar's on it, and it makes it look great. So will regular Son of a Gun or Turtle Wax spray protectant, though. All of these will not have the same longevity there as they will on the cladding, and I'm not sure what the long-term affects will be of applying them to a painted surface, although so far, so good. Done right, it will not look greasy, but even so, things like dust and pollen tend to stick to the insert in particular after you apply any of these to it, so try using a car duster for touch-ups if you go that route. However, I have found that waxing the insert has helped a lot with just maintaining an even look (not splotchy or streaky). It's okay to wax the hood insert because it's actually painted and is not bare polypropylene like the cladding. I think what I'd recommend is doing that first of all so the paint is protected.
    I have also seen kits before that are color-specific, where you can use something much like a wax to enhance color and then you wax over it. Usually I think you use a mild rubbing compound first to prep it. If there is anything out there for restoring luster to black paint jobs specifically, for instance, that may be a good way to go too. I did this with my Mom's red sports car and it still looks great after quite a while now. I prepped it first with 3M rubbing compound - the mildest, least abrasive version they had.
    2001, White (IRONMAN), VehiCross, 0201
    Smile
    I have been using the Meguiar's- nxt generation Tech Protectant on my hood insert. It doesn't give it a glare in the sun and makes it look brand new. I also was using it on the cladding until I applied the TS-1 by Armor-Dillo. The TS-1 is great and after a couple of cleanings and a mild rain today it is still holding up. I love this stuff so far.
    James
    Arachnid J
    Titusville,FL
    '01 Ironman VX
    #0201
    2000 Proton Yellow VX 0586
    Try the color match wax. I think it's Turtle wax, but I can't find the bottle in our garage of junk. I used it once and it doesn't look too bad after 1 washing and all the rain/snow we've been getting. No prep use just like wax.
    Feb 2005
    01, Black, VX,
    thanks so much for all of the help! not to be stereotypical but im a girl and dont know much about cars let alone a vx, but im learning
    thanks again!
    Mar 2004
    2000 Firefox Red 0758
    I use Rain-X on the hood insert.
    May 2003
    '99 Astral #1613
    Exclamation
    t2p, I just treated my windshield with Rain-X, and the instructions say to avoid using it on painted surfaces and plastics.
    FLBeachgirl, don't sweat it - before I had a vehicle I was this crazy about and before I found this website, I don't think you could have found many folks who knew much less about cars than me.
    I would actually wax mine. I have used all sorts of wax and it was fine. Being the middle fo winter, all cleaning products and wax leave my memory since it's been a LONG while since my VX has been cleaned now. Using wax, the insert will get a bit more shiney than the stock matte color should appear, but it looks pretty good nevertheless.
  1. cleaning egr
    By evillecutter in forum VX Troubleshooting...
    Last Post: 12/21/2012, 04:49 PM
  2. hood insert cleaning and maintenence tips?
    By hugoart76 in forum VX Troubleshooting...
    Last Post: 06/08/2008, 03:28 PM
  3. EGR cleaning gone bad :)
    By Dare2Dream in forum VX Troubleshooting...
    Last Post: 10/12/2005, 08:21 PM
  4. Cleaning out the hood insert drainage ports?
    By VX4EJR in forum VX Talk...
    Last Post: 12/07/2004, 04:08 PM
  5. Hood Insert cleaning
    By Robert in forum VX Modifications...
    Last Post: 07/23/2003, 08:43 PM
