Results 1 to 5 of 5
Thread: Parking light removal
    Feb 2005
    2001 Ebony VX 0448
    Can the front round parking lights be removed from the front without removing anything else? My hands are way too big to gain access from the back.
    Jul 2004
    2000 Black VX 0363
    well, yes and no
    Its easier to go up from below. Twist the light housing and then push them out the front of the cladding.
    I haven't tried just twisting the light, but I think it would be pretty difficult to do without a suction cup or something :P
    2000 Black VX 105k
    May 2003
    Wink
    Yes...rotate counter-clockwise until the socket tab lines up with the cladding hole and it'll come straight out as the wire harness is quite long. It just uses one of those small bulbs...#194 clear I think.
    The hard part is the small rubber "O-ring" gasket/seal can make rotating the socket/lens a bit tough as it drags on the cladding. Personally...I used a few drops of fishing-reel oil (looks like a hyperdermic needle) dispenser to lube the "O-ring" gasket/seal which allowed the socket/lens to rotate alot better.
    I did this about 2 years ago (after hitting a ring-necked pheasant! ) and no harm seemed to come to the seal or cladding.
    To reinstall..just line up the socket tab to the cladding hole and insert socket and turn clockwise until "nissan" on lens looks straight...
    May 2002
    2000, Proton Yellow, VX, 0584
    My hands are pretty big and I was able to get to the lights by putting my hands in trianglular space between the radiator and headlight and grabbing the rear of the lamp housing while grabbing the front of the lens with the other hand. If I remember correctly. leftly loosey, righty tighty.
    Scott / moncha.com
    Try a pair of rubber gloves for added grip.
  1. marker light removal?
    By ipd in forum VX Modifications...
    Last Post: 05/15/2017, 05:15 PM
  2. ABS light removal
    By tom4bren in forum VX Modifications...
    Last Post: 06/20/2013, 08:57 AM
  3. Parking Brake Light
    Last Post: 09/21/2007, 01:34 PM
  4. Parking/Marker light question...
    By jigster in forum VX Troubleshooting...
    Last Post: 06/28/2005, 08:50 PM
  5. How do I unscrew the round parking light to replace bulb??
    By zacflash in forum VX Troubleshooting...
    Last Post: 02/12/2004, 02:31 PM
