Results 1 to 8 of 8
Thread: quarter inch rubber which goes around headlite
    Feb 2005
    2001,proton,0519
    Does anyone know what is supposed to hold that thin piece of rubber that goes around the headlite and the body. Mine is just flapping in breeze.looks like someone tried to glue it and looks bad. What is supposed to hold that rubber in place?
    2001,Black,VX,0701
    Glue is what holds it down. a lot of pepole have that problem including myself. black silicone or some other flexable glue works just fine.
    rubber on headlight
    There is a link on this website that shows in pix on how to fix it. Someone used Gorilla Glue to do the trick. Right after I bought my VX last month I about freaked when I heard a thumping sound on the freeway until I figured it out when I got out. Apparently this ranks up there with the window problem in frequency.
    -Wekilled
    douglaswekell(at)gmail.com
    May 2003
    '99 Astral #1613
    Yeah, I saw one almost just like mine for sale at a Toyota lot a while back and it had one flapping in the breeze too. I bet the dealer heard about that. :-)
    Aug 2003
    1999,Silver,Vehicross,0928
    i superglued it on about 2 years ago
    ________
    MEDICAL MARAJUANA DISPENCERIES
    2001 Proton VX #0662
    Superglue can put a permanent white crusty 'fog' on surfaces near the application, especially clear plastic. I'd try something else. Duco cement worked well for me, but you can only get it at neighborhood hardware stores anymore and who gives them any business now that we have a HomeDepot on almost every corner?
    Canadian VXer!
    2001, Proton Yellow, #0580
    I used automotive trim cement (it's like black contact cement) made by 3M - you can find it in automotive stores like Pep Boys (comes in a red tube/box).
    It's easier to actually remove the grill so you have access to most of the lights (at least if the trim has pulled away in that area). Some have actually removed the entire light for an extra clean install.
    -- John
  1. quarter glass
    By Bob Barker in forum VX Modifications...
    Last Post: 05/07/2015, 07:06 AM
  2. 35 inch tires
    Last Post: 11/01/2011, 02:41 PM
  3. PB hits the quarter C
    By Ldub in forum VX Talk...
    Last Post: 10/14/2011, 05:24 AM
  4. Annoying Squeak in Rear Quarter-panel Area
    By k4tmc in forum VX Troubleshooting...
    Last Post: 08/27/2007, 05:04 PM
  5. The 1/4 inch Mod?
    By dtruax in forum VX Talk...
    Last Post: 07/17/2003, 11:46 PM
