Results 1 to 10 of 10
Thread: Shifter Detent
    Feb 2005
    2001 Ebony VX 0448
    Shifter Detent
    Is there supposed to be a detent at 'D' when moving the the shifter from 'N' to 'D'. My VX (just purchased) goes right thru to '3' and it's annoying to have to move it back to 'D' - unless that's the way it's supposed to be. I can live with it but inquiring minds have nothing much to obsess about
    May 2002
    2000, Proton Yellow, VX, 0584
    Nope,, yours is fine. At least, that ishow mine works too.
    Scott / moncha.com
    Feb 2004
    '01 Ebony #0830
    hmmm.
    I remembered this thread when I got in my car this morning... mine has a firm stop at Drive. There is effort to put it in 3rd. Hope that doesn't scare you.
    SilverBullet75
    Formerly: '01 Ebony VXSTLTH
    Now: '08 Saab 9-7x Aero 6.0L
    '99
    Sounds like everything is fine with your shifter. Where you see the black arrows, you can shift freely without pushing the button. To shift in positions shown with the white arrows, you must push the button first.
    Mark
    Once you press the button and move to reverse, you can move all the way to 3rd and back to N WITHOUT pressing the button - back out of the driveway and then move it to D or 3 - 3rd is prefered for city driving so the VX has more power does not have to unlock the converter and downshift so often.
    2001 Proton VX #0662
    To the first poster.... are you saying your shifter doesn't stop at all at the D position or just that it doesn't lock into D and require the button to move further? Mine definitely stops very securely in D before moving further down to 3, but it doesn't lock in D.
    Canadian VXer!
    01 Proton VX.0851
    Tone, what do you mean when you stated 3rd is prefered for city driving? Can you please explain, and at what speed can you take it to in 3rd w/out harming the tranny? Thanx, Bruce
    Feb 2005
    2001 Ebony VX 0448
    Thanks for the info. The diagram explained it perfectly. Yes, the shifter has a detent in D but I was curious as to if it should stop in D and require a button push to go to 3. Diagram says no so it is working as expected
    Wink
    I think Tone pretty clear as what he said. The tranny is going to do less shifting in third, as the torque converter as well, subsequently being easier on the tranny... and use the power button which also tightens shifting. Do search for further explanation on this topic...
    face the mirror
    2000-Ironman 0219
    It goes from N-D-3 with out having to press the button because there is no damage if you do so at any speed. Going from 3 to 2 however could cause damage at higher speeds, hence it is locked in the two lowest gears, and reverse. This set-up is pretty much standard for 4 speed auto trannies.
  1. New Shifter Idea
    By xcelr8 in forum VX Modifications...
    Last Post: 05/30/2012, 11:42 AM
  2. Shifter VXs
    By Bieredalsace in forum VX Talk...
    Last Post: 10/17/2007, 04:27 PM
  3. Rear door detent broken
    By Ascinder in forum VX Modifications...
    Last Post: 05/27/2007, 02:16 PM
  4. shifter mods
    Last Post: 06/12/2006, 06:49 PM
  5. shifter
    Last Post: 12/12/2004, 10:50 AM
