i may have to buy new rotors for the front if the old ones cannot be turned.anyone that has purchased them already, what brand, where did you purchase, and how much? also did you have any issues ? thanks shawn
1COOLVX
Drilled and/or slotted rotors will not stopp quicker with our setup and heat range pads. The drilled crack easily, and both are noisy.
A better upgrade would be stainless steel flex lines, and fresh fluid.
John C.
I have a set of PowerSlot Rotors w/ upgrade pads and Darlington Off-Road Stainless Steel Braided Brakelines ... very happy with them.
Got the rotors from here:
http://www.truckperformance.com/prod...&sf3=VEHICROSS
Got the SS Brake lines from here:
http://darlington-offroad.com/catego...?UCIDs=1134065
