Can anyone tell me what the pin-out is for these Isuzu switches? I thought I remembered someone else here using them.
Andy
Andy
Its the thrill of the chase
Here ya go.. I did this a while ago and also have them marked as to what I hooked them into so they would light up like they are supposed to.
Scott / moncha.com
Awsome,, Thanks
Andy
Andy, what's your plan for connecting to the back of those switches - or did you get the factory pigtail with them? I am wanting to add a couple of these factory switches, but am unsure of what to sue for a pigtail, since you can't buy them from the dealer.
Radioshack has the very, very small spades to fit over the pins. You may have to order them. I brushed silicone grease on the inside of the pin housing, then attached the wires, then installed the spades. I then used a cool melt gun and filled the cavity with "Glue". with the silicone grease and just a little wiggling, made my own pigtail.
Hey Moncha that is so sweet that you took the time to draw that up. Thanks. I never did get my tail gate switch to light up, but now I will.
Scott,Originally Posted by Moncha
Are you talking about the computer pin ends that you can buy at Radio Shack, or do they have something else that fits better?
I can't remember exacrly.. I'kk look for the pakaging. The computer pin type are too small.. There are regular electrical female "Spade" ends. Still had to modify them a bit but with the homemade pigtail, they work fine. I'll post as soon as I can.
