How many miles do your tires have, and are they all worn the same? You could go and have the codes pulled. Check for any worn or corroded wires underneath the truck. Good Luck!
when I bought mine, the VX would drive ok, no check engine.. but the indicater for the tod pulsated, and the tod would ingage locked for like a second.. it was a continuous cycle happening every second almost. Anyway, I had warrenty, kempt bringing it it.. finally got the transfercase replaced/ They kept changing everything else too in the other visits. I believe it because who ever used it before me, never changed the tires.. Make sure there's a good amount of tread on the tires, and the tire pressure is equal in all tires.. I run at 29 psi.
If you want to get the error code, Autozone and some other parts stores have a code reader and they'll read the code for you for free.
Francesco, it sounds like I have the same probelm, no codes or lights on, but at like part throttle inder 30 mph, my TOD lights go full lock (all three) and continue to cycle up and down, and you can feel the jerking. Once you hit 30 it stops. Did replacing the transfer correct the problem?
Mike Skurich
1969 C3 Corvette Coupe
1988 C4 Corvette Coupe
1992 Misubishi 3000GT VR4
1997 BMW F650ST
2001 VehiCROSS
2002 BMW R1100S
2005 C6 Corvette Coupe
