Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: Targa VX
  1. #16
    I believe one reason why you do not see t-tops and targas on SUVs (well, vehicles with that full cab and rear space), is because at higher speeds, that rear will become such an intense vacuum that passengers in the rear, and eventually the front as speed increases, will be enveloped into an intense "walloping" sound. Many may get that with just having a removable or retractable sunroof, but it wouldnt be as bad as an actual removable cab roof space. I installed an oversized sunroof on my Amigo some years back and I couldnt take out the sunroof unless the rear soft top was removed. That vacuum and compression in the rear got so bad at higher speeds that the soft top was actually tearing at the connection pins. It basically acted as an umbrella or a parachute. I think auto designers keep this in mind when creating SUVs cause even with no removable rear like the AMigo, that vaccuum/compression still exists. I don't how this may affect your driving performance or car stability, but I know that having that sound of air concussion blown into your ears 5 times a second sucked, heh.
    1999blkvcross1743
    R U Going to do it!?!?
    Maybe I overlooked the overall plan, but any idea on how hard/easy it would be to put the top back in on a rainy day and/or if it could be stored inside the vehicle like other t -tops. I'd be really interested in seeing this work! An employee at the MO Air Emmisions testing site asked me if my Blk 99 was a Porsche! Having a Magnaflow single in dual out exhaust being installed tomorrow AM,,,can't wait!!!!
    Thanks,
    Sot
  3. #18
    I dont think a drawing/diagram would help really. If you did t-tops, the rear compartment would easily fit 2 panels. No way it would fit a full targa panel unless you payed it over the rear seats. Those panels would be heavy regardless. You would want a plexiglass fabrication of the panels and have them fitted with the proper seals and mounts so they would fit back in securely. VERY intricate planning and fabrication would take place for this entire project to work correctly. I neither have the time, money, or spare VX to junk in case it failed, to make this happen, haha.
  4. #19
    Mar 2003
    Not only does that photoshop job look kick arse... I LOVE the look! If I had more than one VX, I'd SERIOUSLY consider doing it... oh wait, I DO have more than one VX... hmmm... finish motor swap, get the cut-off wheel out and go to town... btw, I HAVE done something rash like that before... chopped the top (ala targa style) off of my '69 Grand Prix... looked awsome... wish I still had the pictures... great... here I go again... thinking of stuff to do before I finish one project! DAMN YOU!
    Later!
    My Webshots Gallery...
  5. #20
    97 Red VX 0673
    Targa??
    I've been putting a lot of thought into this subject, there was a thread running a while back covering the same theme. This summer I will definately be chopping my VX however I have had to modify my dreams and be a bit more realistic than a full targa.
    My first point is just sit in your VX and look up. Not more than a few inches infront of your head is the top of the windsheild. Then lean your head back and look at where the door pillar meets the roof. Again this is only a few inches behind your head therefore you'd end up with a very slim targa.
    Second to make things look right you have to chop the door frame and create a new window seal against the roof and door pillar. Not easy especially when you consider your roof edge seal will have to be part of your targa pannel.
    Having owned 3 Targa top cars: Porsche 911, Toyota MR2 and Honda CRX and knowing the intricate sealing methods used I feel it would be virtually impossible to get a rain tight seal on a "do it yourself" one off basis. (Only the Honda managed to seal in any weather, the Porsche leaked at the mearest hint of moisture)
    The options I am currently considering is:
    1. A full soft top.
    2. Removable pannel that extends beyond the rear door pillar.
    In any case I will be removing the rear section as it's just begging for it. I'm currently butchering the Tamiya scale model to see how things would look as well as playing with Photoshop so in a while I'll have some pictures to post.
    It's worth bearing in mind I am an engineer so there's every chance I'll trash my VX!!
    Col
  6. #21
    2001,Ebony,VehiCROSS,1092
    BritVX,
    Just saw an episode of "Pimp my Ride" where they took an older Blazer (early '90's) and re-did it. They added the best looking sunroof I've ever seen. It looked mike nearly the whole roof was glass, and the front approx 1/3 openned and slid back over the back part. It made for a lareger than average sunroof openning, and a VERY large glass top. Don't know what it cost, or who made it but it might be more doable alternative to bring in the great outdoors to your VX. Good luck, and keep us posted on your progress!
  7. #22
    97 Red VX 0673
    Thanks for the idea, you've put me in mind of a sunroof that Peugoet fitted to 205's some years ago so I'm going to have a trawl of the scrap yards. It was a simple sliding glass pannel and I think I could adopt the whole thing.
    Col
  1. sunroof or targa for vx?
    By frakkin toaster in forum VX Talk...
    Last Post: 01/18/2013, 02:45 AM
