Results 1 to 15 of 24
Thread: Kuhmo/Nitto/Pirelli which is quietest?
    2001, Yellow, Vehicross, 0786
    So it looks like the most common tires available are the Kuhmo stx, Nitto NT or Pirelli scorpion zero all in 255/55/18 all around the $150 mark
    I'm looking for something that rides quiet and has reasonable life and performance, 95% street, some snow.
    No one seems to publish noise ratings, ayone have any thoughts?
    I gotta buy something this weekend and dont know what to get.
    Thanks
    Pete
    '99 SC Ebony #1961
    Don't rule out the Toyo Proxes S/T Tires. I am running them in a 255/55/18 and they are a great performer!
    2001, Proton Yellow, #0580
    My Pirelli's are louder than stock - how much I'm not sure. They also tend to track ruts in the road a bit but I think that's normal.
    -- John
    '99 SC Ebony #1961
    Good point John mine do the same... but I also have 18x8 aftermarket rims.
    The bigger the voids (open area between the tread) the louder the tire. I assume these are all AT tires so they will ALL be louder than stock but should not be loud like a Bogger.
    Nov 2002
    I'm running a new set of Kumho Ecsta STX in 255/55 18 and they're the quietest tires I've ever heard this side of slicks. Very, very nice tire with a solid competition background as well. $101 each at TireRack.
    Jan 2004
    99,silver,1313
    I have the Kumho's and couldn't be happier. 275x17.
    Chicks dig 'em.
    Really though, great tires in most conditions.
    tw
    Ever since I saw those pix of Worm Gods vx next to the one with little tires and wheels I knew that a vx needs at least 275 's" to be cool.
    the only thing in the way of your goals are your excuses
    '99 SC Ebony #1961
    I believe they are a little nosier than stock... Never had them in the snow. But I think that they might not be that good considering they are a street tire.
    Nov 2002
    Lightbulb
    Here's what you do: Get some inexpensive 16" alloy wheels from a Nissan pickup or Xterra (complete sets about $150) and throw a set of Winterforce (about $62 each) or similar tire on 'em. Those you use seasonally and then you can have the great street tires (Kumho etc.) for the rest of the year. All you need is a corner of your garage to stack 'em in when you're not using them.
    I do this but for rally tires and it works great, especially since I can throw all four tire/wheels in the back with a floor jack and SCUBA tank/impact wrench setup.
    Just my $.02!
    2000, foxfire red, 0474
    Toyo's
    Hi Guys,
    I have the Toyo's and have previously had the Pirelli's. The Pirelli's I found to be pretty hopeless in the snow and were stiff and noisy. I was just relocated to Boston in time for the big storm we had and the Toyo's plowed ahead without any difficulty at all. The steering was responsive and nimble with minimal slippage. I have also found the Toyo's to ride softer and quieter than the Pirelli's I had.
    Just my 2c worth.
    Safe driving.
    Max.
    Was seriously thinking about the KUMHO (<correct spelling) STXs but then found these that come in the exact size I am running in Zeros (275/55/17 - V rated), the Hankook ST RH06
    http://www.1010tires.com/tire.asp?ti...Ventus+ST+RH06
    Ine, are V rated AND have a 420 wear rating (the highest I have found in a SUV performance tire), are inexpensive like the Kumho and available in 16 and 18" sizes that we can use. Guess I need to see them both in person.
    Oct 2002
    '01 keiser grey #1193
    kumho's here no increase in noise. Do track pretty bad in bad spots in the roads. We just got 6 inches of ice and snow they did ok. The road crews here SUCK . The salt here is more sand and it takes days to clean the streets off. The wider the tire the worse performance in the snow. I went any where I wanted to passed 20 cars in the ditches. There seems to be min. wear on them with 13000 miles. Worse thing is the tracking in the ruts next time I'll get skinner tires because I'm seldom off road.. They do look sweet . The other sday a fine ***** young lady came up and was hardly able to control herself after seeing them .....no not really , but they are sweet
    VX...Priceless...Everything else there's mastercard..
    Ended up with Yokohaha Geolander 52's in 255/55/18 after finding the reviews section in i think it was tireracks website they had the best overall score on noise and snow/ice ratings in my price range. $668 installed.
    So far i'm very impressed, they are definitely way quieter and smoother than the stock bridgestones, my driveway is all ice and snow at the moment and they get me up and down there much better too.
    So, thanks everyone for the input, incidentally i did try the local Cooper tires dealer, they would not supply them as they were a different rating to what was called for for the VX, softer wall i think he said.
    Pete
    2000 Proton Yellow VX 0586
    Thumbs up Way to go Kumho
    I don't know if Kuhmo's are the quietest but I will tell you that my boyfriend races offroad for Kuhmo and has never had a flat or hardly any extreme wear on his tires and he uses regular street ATs and MTs. With all the open wheel banging and torn off truck parts to run over, they are a tough tire. Before he raced for BF Goodrich and was dropping $125 per race per tire! So I'd give the thumbs up to Kuhmo. ( This is not an ad!)
    Past Owner
    The Kumho STX seem quiet (can't hear them over the PV2) and grip very well in dry and wet. Just for fun, I tried them a few weeks ago in the snow. I won't try it again. On another note, I posted a review of the Yoko Geolander 052s in another thread. They are a great performing four season tire that come big enough to look good on the VX.
  1. Replies: 2
    Last Post: 07/26/2007, 02:40 AM
  2. Snow tires - Blizzak or Pirelli Scorpion?
    By Cobrajet in forum VX Talk...
    Last Post: 11/09/2004, 03:02 AM
  3. Got my Nitto's
    By autox-racer in forum VX Modifications...
    Last Post: 08/13/2004, 04:27 PM
  4. Kuhmo Tires
    By I_Wanna_Retire in forum VX Talk...
    Last Post: 03/12/2004, 05:11 PM
  5. Pirelli 285/60/18's
    By transVXmen in forum VX Modifications...
    Last Post: 02/12/2004, 03:11 PM
