Alaskavx asks: "Do a lot of people run CB's down there?"
Answer: Yes. Most clubs have CBs as a mandatory item. It is also recommended for most trail rides. It is a way to stay in touch with the rest of the group and call for help if necessary.
tomdietrying says: "can't you put the same frenquency on your walkie- talkie as the CB?"
Answer: Not on the Garmin 120. It uses the FRS frequencies that are different than CB wavelenths.
Also: If I remember, I will have two hand helds and 2 magnetic mount antenas with me for loan.
Steve G
