Results 1 to 4 of 4
Thread: Need Help with frost
    Apr 2003
    2001,Proton,????
    I think I found the problem. He was leaving the 'inside circulation' button turned on, so that no outside air was coming in. As you state, you need some outside air to absorb the moisture exhaled by the passengers. I turned the button off, and drove it into town and back, and the windows are pretty much cleared up now. Will be able to tell for sure if this is fixed when we wake up tomorrow morning, as it will be 15 to 20 below.
    Remove trim at door sill. Stick hand under carpet at lowest point possible on floor(if not frozen stiff). Check for moisture.
  1. Frost Guard
    By JayDallas in forum VX Talk...
    Last Post: 01/03/2015, 08:53 PM
