Results 1 to 3 of 3
Thread: Engine surging
    Apr 2003
    ex IronMan
    Check your fuel filter and intake gasket. Our engines are known for bad " vaccum" leaks on intake gasket. This might contribute to your condition.
    Andrey
    '99 Ebony Black VX, 0339
    Idle control valve mounted on the throttle body could also cause this - it gets gunked up over time. It is held in place with 2 Torx screws and can cleaned with carb cleaner and checked for easy movement. May also want to take intake tube off and spray intake cleaner around the butterfly as gunk builds up there and could be preventing it from closing all the way. TPS could also cause this but the intake gaskets are notorious for this. Clogged fuel filter is unlikely to cause this behavior.
  1. Surging RPM's at speed
    Last Post: 03/23/2015, 05:25 PM
  3. RPM surging, rough shifting, overheating
    By Heraclid in forum VX Troubleshooting...
    Last Post: 05/28/2010, 11:10 PM
  4. Engine surging AGAIN
    Last Post: 08/28/2005, 10:54 AM
  5. Replies: 1
