Results 1 to 3 of 3
Thread: turn signals
    Dec 2004
    2000 yellow vehicross 0702
    turn signals
    turn signals will not flash off and on. they will come on but not flash. hazzard lights are the same way. the fuse is ok. can not find silenoid that controls blinking.
    Apr 2003
    2000, Dragon Green, 0808
    This usually indicates that one of your bulbs is out. Is it in both directions of turn signals?
    There is a conventional round turn signal relay under the dash behind the fuse panel and it is most likely the cause. Lamp out will not cause this. One other cause would be a loose ground at the fuse panel. What have you changed recently?
  1. Replacing relay/flasher for LED turn signals
    By Bill Brown in forum VX Modifications...
    Last Post: 05/07/2020, 02:44 PM
  2. How to: blacked out turn signals
    Last Post: 08/09/2017, 12:47 PM
  3. Cruise control/turn signals acting up
    Last Post: 10/07/2010, 08:53 AM
  4. I hate turn signals!
    By WyrreJ in forum VX Talk...
    Last Post: 08/24/2005, 08:23 PM
  5. 50w halogens no good for turn signals?
    By WyrreJ in forum VX Modifications...
    Last Post: 06/08/2003, 11:00 PM
