Results 1 to 15 of 21
Thread: Gas Mileage
    2001 Proton 0951
    Gas Mileage
    Can anyone suggest a way I can improve my gas mileage? Right now I'm getting about 11 mpg, local.
    Can a new air filter improve mpg? Any suggestions greatly appreciated.
    Life is what happens when you're driving a VX...
    2000-Ironman 0219
    Mileage
    eleven Mpg is totally out of hand. . How many miles does your VX have and what type of maintenance has it received? Bad mileage can come from a lot reasons, from dirty aircleaner to bad EGR.
    I have 2000 with 60k and avg 15 city and 18 hwy
    2001 Proton 0951
    It has 41K on it and I change the oil very 3K. Just had the diff fluids changed as well as the fuel filter. It runs beautifully but the mpg is lousy.
    2001 Proton 0951
    The air filter is new also. I keep 40 psi in the tires (max 50 psi), so I'm at a loss what to do.
    2000-Ironman 0219
    Mileage
    A diagnostic might be in order. At that mileage even paying a professional will be a good investment. For one thing, if they check your smog it should show if you are running rich. 11mpg is unacceptable, even for a VX. How long has it been that way?
    '01 Ironman
    FYI- With my lift and 33's and cold weather I am seeing 10mpg.
    Is 10MPG corrected for your vastly differnt tire size? 11MPG in town for a VX IS well within reason depending on how you drive, tire air pressure, etc. - but a look under the bonet never hurts...
    2001 Proton VX #0662
    Yeah, big tires will make it look like you are getting worse mileage than you really are... since they fool the odometer into thinking that you haven't driven nearly as far as you really have per gallon.
    Canadian VXer!
    2001 Proton 0951
    I've been getting 11 mpg since I bought it a year ago. It runs like new but when I read about VXers getting 15 or 18 mpg local, makes me wonder what's wrong. I'll have to have a diagnostic run.
    May 2003
    2001, Kaiser Silver #1213
    Not to high-jack your thread H but,
    mine has been getting progressively less mpg since I owned it.
    a friend suggested I may have a fuel line leak, since he can smell gas fumes when I turn over the engine.
    any suggestions?
    2001 Proton 0951
    I think the best course of action would be to have a diagnostic run from an Isuzu service center (I won't let anyone else touch my VX). That should answer your question. I'll definitely get mine done after the holidays and will keep you posted. You do the same! :-)
    Ex-Owner of a 2000, Kaiser Silver, 0216.
    Dude, not to slam you but YOUR NUTS That is the LAST place I'd ever go! Most Isuzu shops don't even know what a VehiCROSS is! I'd find a good mechanic you trust and stay away from Isuzu. And if your worried about having a warranty issue, just do a search on others who have tried to get warranty work done. Isuzu fights you on all issues, claiming it's not a warranty covered part anyway. I've had my VX for 4 years, and only went to Isuzu ONCE, and never again. I have my own personal mechanic do all my work!
    Dave...
    Always a kid at heart!
    99 white ironman
    I changed my air flter and then went to cerami isuzu to get my wheels aligned, wheel bearings greased, and all the 4x4 parts fluids flushed.. 450 bucks. I went from 17 hwy to about 19.5.... and that lasted a while.. It's now down to 16-17 hwy and that's after I upgraded the exhaust. Expect to get less mileage in the winter as an additive is used in your gas for cold weather operations. Also, check the tire pressure since 29 is the require pressure. This is import more for the TOD than the mpg..... my transfer case went bad, but I'd like to thank Cerami for warrenty work cost me nil! I was expecting to get 20-21 hwy with the new exhaust, but now with winter it's hard to tell exactly.
    2001 Proton 0951
    I've been using Belleville Isuzu since I got my VX and they've gone above and beyond and their service is great. I'm no longer under warranty and got an extended warranty but haven't had the need to use it yet.
    Before going to Belleville Isuzu, I had 3 local mechanics tell me they wouldn't touch my VX. I know alot of people have had bad experiences with Isuzu but Belleville knows what they're doing and I swear by them, and believe me, I'm not easy to please when it comes to my VX!
    Mar 2004
    2000 Firefox Red 0758
    I consistently get 15+ mpg combined ...... (a few times over 17 mpg) .... this has been a welcome surprise.
    But then again, I probably drive like an old toad compared to some ....... most .......... ?
    I really like the power characteristics of the 3.5 Izu engine .... it is smooth and has decent low end and a good mid range 'punch. The engine - combined with the low gearing, trans ratios, and the characteristics of the torque converter - allow me to drive around the rural roads, etc. effortlessly ........
    Generally, I take it easy from a standstill ...... and usually cruise around the highway at 2500/2700 rpm ..........
    My VX is shod with 255-55's ........ usually run around 38 psi ......
  1. Mileage
    By cascabel3 in forum Polls
    Last Post: 09/09/2015, 05:16 PM
  2. Gas Mileage
    By Mile High VX in forum VX Talk...
    Last Post: 02/17/2010, 12:10 AM
  3. Gas Mileage (again)...
    By kobie in forum VX Talk...
    Last Post: 10/13/2008, 09:36 AM
  4. What is TOO much on MILEAGE!?
    By SachaK in forum VX Talk...
    Last Post: 09/12/2004, 11:46 AM
  5. Gas Mileage
    By Hanalei in forum VX Troubleshooting...
    Last Post: 06/08/2004, 08:00 AM
